Old Aug 11th, 2003, 12:41 PM   #1 (permalink)
the don 1600
lost and found
the don 1600's Avatar
Send a message via AIM to the don 1600
soft brakes
my brakes seem a little soft. i checked the pads and they have alot more left on them. fluid level is fine. and i just got the drums done about 2k miles ago. i was wondering if theirs anything i can do to tighten things up. i saw the guy when he was doing my drums that he twisted something close to the drum clynder and the brakes got tigther cause he couldnt put the cover on. so he had to losen them. but what about the calipers. will bleeding them help?
the don 1600 is offline   Reply With Quote
Old Aug 11th, 2003, 04:27 PM   #2 (permalink)
bahearn
bitter old man
bahearn's Avatar
Drum brakes usually are designed to adjust when applying brakes in reverse. To manually adjust, there is a star wheel visible through a slot in the backing plate. Use a screwdriver to spin the star wheel. Sorry, I don't know which direction.
Bruce in Houston
bahearn is offline   Reply With Quote
Old Aug 11th, 2003, 08:44 PM   #3 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
Bleeding your brakes may help. If the fluid's old (if it's dark brown or even black), drain it completely (empty the brake fluid container with a turkey baster). Try to get DOT 4 or DOT 5.1 fluid. It'll last longer and fade less regardless of how you drive (how much longer and how much less obviously does depend on how you drive).
Captain Slow.
Old Aug 11th, 2003, 11:32 PM   #4 (permalink)
the don 1600
lost and found
alright thanks guys
Old Aug 12th, 2003, 02:01 AM   #5 (permalink)
Wont Be Beat
Send a message via AIM to Wont Be Beat
Its definetly time for a bleed.
Accordingly Done
Wont Be Beat is offline   Reply With Quote
Old Sep 8th, 2004, 05:32 PM   #6 (permalink)
Hendrix
What's in your wallet?
Hendrix's Avatar
Send a message via AIM to Hendrix Send a message via Yahoo to Hendrix
Guess what I just did? I searched and found that this may be the answer to my braking problem. Thanks guys
Hendrix
"Have you heard of the chain of command? It's the chain I beat you with until you realize that I'm in command" - Firefly, Jayne. Affirmative Action MoFo
Signature edited to please Scoot
Hendrix is offline   Reply With Quote
