Old Jul 25th, 2002, 08:32 PM   #1 (permalink)
RATED-R
Posts: n/a
Unhappy E-brake problem
Pop quiz hot-shots?
When I pull e-brake it works but not well. If I pull it up to high it locks but not to the point where I can't move but to the point where I'm killing the pads. HELP!!!
Old Jul 25th, 2002, 10:50 PM   #2 (permalink)
CarbonBlack200
Platinum
CarbonBlack200's Avatar
Send a message via AIM to CarbonBlack200
Post
Sounds like your rear calipers needs to be overhauled... And maybe you can adjust the cable..
CarbonBlack200 is offline   Reply With Quote
Old Jul 27th, 2002, 01:59 AM   #3 (permalink)
RATED-R
Posts: n/a
Not the cable. But I do have to check the calipers.
brake fluid level problem minute rice sentra B11/B12/KN13 82-90 chassis 4 Jul 28th, 2003 06:28 PM
brake problem... dry B14 95-99 chassis 2 May 31st, 2003 06:42 PM
Drum parking hand brake problem nyit240 B11/B12/KN13 82-90 chassis 7 May 3rd, 2003 05:02 PM
Charging problem: Brake & Charging lights both on tucson_b14 B14 95-99 chassis 8 Mar 28th, 2003 04:32 AM
Front passenger side brake problem nyit240 B11/B12/KN13 82-90 chassis 1 Oct 17th, 2002 12:11 PM
