brakes squeeling, need to lube caliper tracks?
I have a '97 Nissan Sentra that I've had for about 4 months. Once I've been driving for a while, and only once i've been driving for a while, when I brake with a certain ammount of force I get a really good squeel. The wierd part is that when I start to accellerate again they still squeel. It's a squeel that sounds like it would be made from metal on metal with no lubrication. I took it into a shop and they took apart my front brakes and they told me that I have heat cracks in my pads. They said that whoever put on the last set of pads (which are still at least 75%) they did a cheap job and didn't lube up the caliper tracks that the calipers slide back and forth on. So they think that when I brake, they calipers don't completly open up and stay rubbing against the rotor, heating it up to not normal temps, causing the heat cracks. They wanted to charge me $250 to replace the pads and lube it up. I want to just do it myself, it's just disc brakes, very easy.
The part I want to know is how do I lube up the caliper tracks so this doesn't happen again? I've never done that part before when I've done a brake job.
