Rear brakes "dragging" rotor
I finally got my Goodridge SS lines on. I also installed Powerslot rotors on all four sides, hawk pads in the front, and remsa gold pads in the back. I test drove the car last night and the pedal feel was much softer than I expected, but the main problem was the grinding noise coming from both back brakes. I looks like the pads are rubbing the rotors when the brake is not pressed. There is a grinding noise, but the noise stops when the brake is pressed. It appears that the pads are not making contact with the rotors on the outer edge.
Also, the emergency brake is very loose and does not stop the car well.
Any ideas?
1999 Sentra SE-L
