If your rear wheel is rubbing the strut, lowering has nothing to due with the problem. It's all about offset...apparently your wheels have too much negative offset. The larger the wheel diameter, the more negative offset you can utilize, but your wheels still have too much offset.
Looks like 1/2" spacers are in your future, as well as NISMO 50 mm wheel studs. I doubt the stock studs can deal with 1/2" spacers.
Or, send them dumb wheels back and get a set with less offset. Typical B13/B14 applications use 32-38 mm offset.
Oh, and you're hurting your acceleration with wheels that big..and heavy.
Bruce in Houston
