Old May 8th, 2003, 01:46 PM   #1 (permalink)
kev
suspension "creaking" sound at low speeds
I've got the GC/AGX combo for my 200sx with 300 F /250 R spring rates. As of late, I've noticed when parking...or leaving a parking spot I'll hear sort of a creaky sound (almost sounds like a "springy" noise)
It happens when the wheels are turned at VERY low speeds (5mph or less).
Anybody else experience this or know what I'm talking about. If so can you explain what is making the noise. Is this normal and if there is anything that can be done to prevent the noise?
Thanks in advance
kev is offline   Reply With Quote
Old May 8th, 2003, 07:46 PM   #2 (permalink)
Pacman
I LOVE MY COUPE
Send a message via MSN to Pacman Send a message via Yahoo to Pacman
I think it might be your bushings, the grease might be gone. That would cause a sqeaking noise.
Here it is. Now with pics for your viewing pleasure.
My 240
Pacman is offline   Reply With Quote
Old May 9th, 2003, 12:31 AM   #3 (permalink)
Skinny G
Hideous Hardbody
Skinny G's Avatar
I found the OEM dust boot would squeak against the top spring mount up front when the wheels were turned. A liberal coating of grease on the top of the boot and the contact part of the upper spring mount eliminated it.
Tokico Springs, KYB AGX.
Other than that, I'd give the nod towards bushings as well.
Lose 1000lbs - ask me how! The Lethal Locost
Skinny G is offline   Reply With Quote
Old May 9th, 2003, 07:45 AM   #4 (permalink)
Phil I.
The creaking noise your talking about sounds pretty similar to the problem I had when I installed my JIC FL2-A2 coil-overs on my 2001 Eclipse. It turned out the front struts weren't bolted on tightly enough.
Phil I. is offline   Reply With Quote
Old May 9th, 2003, 01:52 PM   #5 (permalink)
057
I just installed the same set up and I hear the same exact noise.
057 is offline   Reply With Quote
Old May 9th, 2003, 02:21 PM   #6 (permalink)
dreadsword
Nissan Fanatic
dreadsword's Avatar
I've got a similar noise on my bone stock 1600NX and have just accepted that its suspension weirdness. Which is a good thing - at first I was afraid brake cylinders or something were leaking and soaking the drums and that the creaking was the rear drums grabbing unevenly on fluid soaked surfaces.... not that you SR20 types have rear-drums to worry about.
dreadsword is offline   Reply With Quote
Old May 9th, 2003, 04:40 PM   #7 (permalink)
057
no sr20 here
Old May 9th, 2003, 06:47 PM   #8 (permalink)
kev
Pacman, which bushings exactly?
Skinny G, it's not the dustboots cuz I don't have dustboots
Phil I, the struts are properly torqued
057, i do have the sr20
Very interesting I wanted to make sure it wasn't anything MAJOR, but I will look into fixing it
Old May 12th, 2003, 06:09 PM   #9 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
how are the coilover bodies fastened to the strut?
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old May 13th, 2003, 08:51 AM   #10 (permalink)
057
I followed this installation procedure http://www.nissanperformancemag.com/...spension.shtml
Duct tape and silicone
Old May 13th, 2003, 05:27 PM   #11 (permalink)
kev
I did the same method, but skipped the silicone part.
Old May 19th, 2003, 04:58 PM   #12 (permalink)
kbrassfi
Nissan Fanatic
kbrassfi's Avatar
Send a message via AIM to kbrassfi Send a message via MSN to kbrassfi Send a message via Yahoo to kbrassfi
did you put the little orange gasket back on the top of the strut assembly, if you skip this, there will be noise, because its metal on metal, I forgot the gasket and didn't worry about it, then after a day the sound got annoying and I dropped the assembly again to put it on
My 96' 200sx
kbrassfi is offline   Reply With Quote
Old May 20th, 2003, 01:30 AM   #13 (permalink)
kev
Yes, I did keep the orange gaskets back on.
Old May 21st, 2003, 11:26 PM   #14 (permalink)
kbrassfi
Nissan Fanatic
kbrassfi's Avatar
worth a try, sorry
My 96' 200sx
