Old May 5th, 2003, 09:59 AM   #1 (permalink)
lowmileage
lowmileage's Avatar
Rotor removal on '91 SER
What is the procedure to removal/replace the rear rotors. After you remove the caliper, does the rotor "just come off" or do you have to drill out rivets? I'd like to order new rotors today but I'm at work and the manual is at home. Just like to know the involvement of the job.
Thanks
lowmileage is offline   Reply With Quote
Old May 5th, 2003, 11:23 AM   #2 (permalink)
By Nature
Nissan Fanatic
Send a message via AIM to By Nature
rotors should slide off.. they're held to the hub by lug-nuts.. sometimes they might be held by rust to the hub... gently tap it with rubber/wooden hammer from the backside to remove it
"Those who stand for nothing, will fall for anything"
2003 VW Jetta 1.8
1998 Nissan Sentra 1.6
By Nature is offline   Reply With Quote
Old May 5th, 2003, 11:45 AM   #3 (permalink)
lowmileage
lowmileage's Avatar
Thanks, always good to know that the job is a simple take off, put on
