I have the Fastbrakes kit on my car... they make a big difference. I think your kits use Dynalite 4 pistons, though. You just have to pay more attention to them because they don't use outer dust boots.
Wouldn't it be cheaper to go to the junkyard and get 4th Gen Maxima calipers/rotors? My stock were 11" rotors... Should be more than enough for your lighter cars. I think most Nissan FWD bolt on without much problems... though I haven't personally done this swap.
Originally posted by Chunger I have the Fastbrakes kit on my car... they make a big difference. I think your kits use Dynalite 4 pistons, though. You just have to pay more attention to them because they don't use outer dust boots.
Caliper offset and bolt center to center are wrong as is the rotor bolt pattern.
Damnnit, there are way too many tempting mods out there that I want and would automatically take me out of STS! It's good to know though cause once I get my cage in the next month or two I'll certainly need them for track use.
Ok, so someone asked if this would fit the b13... Well, was that just the SR20 or would that also fit the GA16? Or is there even a difference between the two?
Originally posted by TheNatrix Ok, so someone asked if this would fit the b13... Well, was that just the SR20 or would that also fit the GA16? Or is there even a difference between the two?
The brembos won't fit they are way too big, only B15.
I was part of the initial group buy for Fastbrakes Someone had installed their 11" kit and posted the pic.
Before
After
I have bought the 11" Heavy Duty Slotted rotor. I was told that I didn't have to change the MC. The owner of the picture posted above did not have to replace his MC. You just need to properly bed the rotor, I was told, and it would be fine. The brake pedal will be firm.
