Sportlines
yea I have the SPortlines on my 98 SE-R with 17 inch tires. If you are running the stock wheels it sits a lot lower with the 15 inch rims (actually 14 inch in your case). It will definately bottam out a lot, but if you are going to the 17inch set up the car sits a bit higher. My opinion the perfect height. The car rarely bottams out and it looks just right with the aftermarket wheels with a little tuck in the rear. There is not much bouncing at all and I have just the stock shocks. So if you are gonna go to a 17inch or even 16 inch set up I most definately would go with the Sportlines (1.9" drop).
98 200SX SER; PR CAI, strut brace, 17"Rota Wheels, 215/40/17 Parada Spec 2's, Tein SS Dampers, HS Headers, ACT stage 1 clutch
