Old Jul 2nd, 2002, 09:30 AM   #1 (permalink)
SERialThreatz
Rear Tires Rubbing??
question?? maybe sum of you guys can give me more help, i just got a whole new suspension Intrax springs(2 "drop) and Cambers and KYB's, just the other day i added my rims and the rear is touching my struts i could't even reverse?? do you think it could be the cambers that were adjusted slightly too far in, cause my rims are really tucked... should i put back the original spindle bolts?? will that take it back to its original place?? Let me know...
thankx
UNDERCONSTRUCTION:SOON TO BE SOLD...FULLY EQUIPED..
SERialThreatz is offline   Reply With Quote
Old Jul 2nd, 2002, 07:13 PM   #2 (permalink)
CarbonBlack200
Platinum
CarbonBlack200's Avatar
Send a message via AIM to CarbonBlack200
Post tire size?
what size of tires do you have?
CarbonBlack200 is offline   Reply With Quote
Old Jul 2nd, 2002, 09:20 PM   #3 (permalink)
SERialThreatz
i got 17x7s'
Old Jul 3rd, 2002, 05:43 PM   #4 (permalink)
Psch91
PB JELLY TIME!
Psch91's Avatar
Send a message via AIM to Psch91
SERialThreatz, not rim size, tire size ###/##/###
Sun Burst 04 Spec-V: Gen II Nismo CAI - Megan Racing header - IM Pulley - JWT Cams - Motor Mount Inserts - HPA Downpipe - Apex'i WS2 - Faktion Gen2 Short Shifter - Custom Lip - Tinted Windows
Psch91 is offline   Reply With Quote
Old Jul 3rd, 2002, 08:47 PM   #5 (permalink)
Kelway
Yeah, on a 7" wide wheel, you are probably running at least a 205 width tire. The offset on the wheel is probably 40mm. You will have to put spacers behind the wheel. 4-5mm should do it, I think. Some people can run 205's w/o rubbing but a lot have to have spacers.
'92 NX2000
Kelway is offline   Reply With Quote
D21 rear disc brake conversion scoobysmak Truck & SUV 13 Jul 5th, 2006 05:58 PM
SEMA show Spec V's and other Nissan GOODIES cjsmith11878 General Discussion 13 Jan 26th, 2005 09:51 AM
B12 Sentra rear susp sinking problem nyit240 B11/B12/KN13 82-90 chassis 17 Sep 2nd, 2004 06:46 AM
17'' wheels rubbing in rear @ stock height???? maxpower559 B13 91-94 chassis 13 May 17th, 2004 11:33 AM
tires...tires...tires.... RED350Z Z33 350Z 2003+ 18 Dec 8th, 2003 11:07 AM
