Old Feb 10th, 2003, 02:26 AM   #1 (permalink)
SentraFi
SentraFi's Avatar
Spec V with Eibach Front and Rear Sway Bars
I was at Willow Springs Raceway in California at the Big Track on Saturday.
Man, what a rush! Dave Royce, Eibach engineer, is the best driver I've ridden with. He showed me what my car can do in the hands of a professional driver. The highest speeds he did was one turn at 90MPH and exiting another at 115MPH. My car always had the secondaries open when he was driving. It hugged every turn, even on stock tires! He drove it twice and concluded that the rear prototype sway bar needs to be stiffer.
When I drove it, the car felt flat in almost all the turns. I was hanging with the Corvettes in the turns Then they blew me away on the straights Here's more in Dragrace/Autocross/Rally Discussion.
I saw Mike Kojima (aka SmartBomb) there and he saw Dave drive my car. He thought the car looked flat in the turns and it looked like it handled very well.
The sway bars are tubular, i.e. bent, round rods. They will be powder coated red. The rear bar is adjustable by sliding the sway bar in or out to adjust stiffness, then locking in place via bolts. The front cannot be adjusted due to space limitations. The front bar replaces the stock one.
The price is not known at this point. Tentative release date will be around 6 weeks from now.
The spring rate of the Eibach Pro-Kit Springs (Part No. 6362.140) is higher than the stock springs on the Spec V. I’ll email him asking what the stock spring rate was and then you can compare it to the Pro-Kit.
It has been tested on a Spec V with Pro Kits installed. You can you use these with the stock springs.
These bars will make the suspension stiffer than the stock ones.
I do not have any experience with the Progress sway bars so I cannot do a comparison.
The front sway bar did not accentuate under-steer during the test drive at Willow Springs. It may have been necessary to change the front sway bars to keep the car balanced.
SentraFi is offline   Reply With Quote
Old Feb 18th, 2003, 11:17 PM   #2 (permalink)
BlackoutSpecV
Nissan Addict
BlackoutSpecV's Avatar
Re: Spec V with Eibach Front and Rear Sway Bars
Is the prokit out yet, or has it been out for a while, because when i called Eibach back in sept/oct the spring rates they told me (for the kit they had out) were lower by about 50-100 than stock.
-- 2002 SE-R Spec V
BlackoutSpecV is offline   Reply With Quote
Old Feb 19th, 2003, 09:34 AM   #3 (permalink)
cburwell
Send a message via AIM to cburwell
Would the front sway bar fit the B15 SE? If I remember correctly progress only makes a rear sway bar for our car (I could be wrong). Little to no body roll is one of the top five things I am looking for when I purchase suspension products.
2000 Sentra SE
cburwell is offline   Reply With Quote
Old Feb 23rd, 2003, 04:34 PM   #4 (permalink)
Ruben
Friends of ours...
Ruben's Avatar
Send a message via AIM to Ruben
Re: Re: Spec V with Eibach Front and Rear Sway Bars
Any news on this? What are the Eibach spring rates? Any know about the ride? Bouncy?
Ruben - O.G. Club Mofo Mobster
2003 Chevrolet Corvette Z06
The Z06 / Z06 Replaced 350z / 350z Replaced Spec V / Spec V Replaced 3.5 AltimaSE
Ruben is offline   Reply With Quote
Old Feb 23rd, 2003, 05:25 PM   #5 (permalink)
Ruben
Friends of ours...
Ruben's Avatar
I found it on thevboard.... thanks sentrafi
Pro Kits:
Front springs are 180 lbs/in progressive design.
Rear springs are 300 lb/in progressive design.
Stock:
Front OE is 150lbs/in
Rear OE is 240lbs/in
Please keep in mind that the pro-kit is designed to provide the best handling in conjunction with the OE dampers. If you add any more rate, you will over work the OE damper as well as produce a harsh ride.
Dave Royce
Eibach Springs, Inc.
