Old May 9th, 2008, 03:14 PM   #1 (permalink)
dh0765
Question Brake Drum Removal 2003 Nissan Sentra XE????
I am having a lot of trouble trying to remove the rear brake drums on my 2003 Nissan Sentra XE. According t the Haynes manual, all I should have to do is remove the wheel/tire and pull it off. It say's if it is still difficult to get off then loosen the tension with the self adjuster. I have done this and it still will not come off. I know I turned the adjuster in the right direction, because the adjustment thingy got loose where I could move it a little bit. I have beat the heck out of it and it still will not budge. Oh, and yes the emergency brake is not set either! Any help is appreciated!
dh0765 is offline   Reply With Quote
Old May 16th, 2008, 11:40 PM   #2 (permalink)
metro273
Nissan Technician
metro273's Avatar
Sometimes we have this problem at work. I have a nice BIG brass hammer that always seems to work. If that don't work, I use a air hammer...this will ALWAYS work! Good luck!
Wishing I was in Sunny Florida!!!
metro273 is offline   Reply With Quote
