Old Jan 30th, 2003, 12:16 AM   #1 (permalink)
AznVirus
1.6 Turbo Power
Send a message via AIM to AznVirus
HELP! Problem with AD22VF Brake Upgrade...
just got the AD22VF brake upgrade from Courtesy Nissan and installed them today. they did NOT come with the torque members so i just bolted the caliper to the control arm (where the stock torque member bolts went). anyone know if running it w/o the torque member is bad?
anyways, ran into so problems and broke one of my lug nuts off while it was still attached to the hub. so need to replace the hub tommorrow. installation went fine and bled the brakes, but problem is that i have no brakes. there is hardly any pressure. im pretty disappointed right now, but im going to bleed them again tommorrow.
any ideas to give out? please anything will help.
1.6 - The Underdog
GA16DE-T Owners Club!
153 HP & 152 TQ
AznVirus is offline   Reply With Quote
Old Jan 30th, 2003, 08:56 AM   #2 (permalink)
theo
Posts: n/a
try bleeding the master cylinder
Old Jan 30th, 2003, 11:46 AM   #3 (permalink)
bahearn
bitter old man
bahearn's Avatar
You must use the AD22 torque member.
Bruce in Houston
bahearn is offline   Reply With Quote
Old Jan 30th, 2003, 06:02 PM   #4 (permalink)
PatScottAKA99XE
ex-Super *********
PatScottAKA99XE's Avatar
Send a message via AIM to PatScottAKA99XE Send a message via Yahoo to PatScottAKA99XE
Like its said above you must use the AD22 bracket. I think you may be confused. Seems to me that there is no way in heck you can bolt up a AD22 caliper without the bracket. You shouldnt have to bleed the master cyl. to change calipers. Im thinking you did not get them bled correctly. BTW yes it would be bad to run the calipers without the brackets...the brakes would NEVER work.
Patrick Scott
Yeah, thats a roll cage in there.
I shall call him...Mini-Me
PatScottAKA99XE is offline   Reply With Quote
Old Jan 30th, 2003, 06:04 PM   #5 (permalink)
PatScottAKA99XE
ex-Super *********
One more thing. You dont have to replace the whole hub if you broke off a lug stud/nut. You can just replace the stud and nut.
Patrick Scott
Old Jan 30th, 2003, 06:25 PM   #6 (permalink)
AznVirus
1.6 Turbo Power
thanks for all your responses. i got 4 new studs for the passenger side hub at the stealership. they flushed my entire brake system and for some reason im still getting a mushy pedal feel. i saw the mechanic flush the system so im stumped why i have so much freeplay in the pedal. any ideas?
i must have got my terms all mixed up. the torque member is the piece that attaches to the control arm and bracket, correct? if so, i did not receive one that fits the ad22vf calipers with my kit from courtesy nissan. i am using the ad22vf calipers + rotors. everything bolted on great and installation wasnt bad at all. but im still not sure why im not getting my full braking capacity.
again thanks for all responses.
1.6 - The Underdog
153 HP & 152 TQ
Old Jan 30th, 2003, 09:22 PM   #7 (permalink)
Naemus
Must be terminology...I always thought the "torque member" was simply the caliper bracket-- ie) the stationary part which houses the moving parts (piston and caliper clamp).
If that isn't it I couldn't tell you what my "torque member" was!!!
Current: kyb agx, eibach pro kit, nx2000 brake kit, HS header, custom intake, magnaflow muffler
Planned: trying to save some money!!!
Naemus is offline   Reply With Quote
Old Jan 31st, 2003, 06:01 PM   #8 (permalink)
PatScottAKA99XE
ex-Super *********
Torque member and bracket..same thing. It is the part the caliper bolts to or you can call it the part that bolts to the spindle. Its all the same part.
Patrick Scott
Old Jan 31st, 2003, 08:00 PM   #9 (permalink)
AznVirus
1.6 Turbo Power
any ideas on the freeplay of the pedal? i just dont think im getting full braking capacity. just doesnt seem right. it may be just because i havent adjusted yet.
1.6 - The Underdog
153 HP & 152 TQ
Old Feb 1st, 2003, 09:38 AM   #10 (permalink)
se-r-57
Nissan Fanatic
Send a message via AIM to se-r-57 Send a message via Yahoo to se-r-57
You can adjust the freeplay on the pedal easy. Look up under the dash and you'll see a rod that goes to the top of the brake pedal. There is a jam nut on it. Loosen the jam nut and turn the rod clockwise to decrease the freeplay. You'll have to play with to get it where you want it. Take the car out and drive it to get the brakes up to operating temp and make shure the brakes don't drag when warmed up. Thats it you'll just have to play with it to get it where you like it and make shure to tighten the jam nut up when your done. Hope this helps.
94 se-r saphire blue with lot's of crap
I'm just a monkey. I don't know shit.
In the white SE-R when the AMG benz did the ricer fly by on 408 :)
se-r-57 is offline   Reply With Quote
Old Feb 1st, 2003, 09:46 AM   #11 (permalink)
MaddMatt
This may be a dumb question, but did you also change the rotors???
MaddMatt is offline   Reply With Quote
Old Feb 1st, 2003, 08:59 PM   #12 (permalink)
AznVirus
1.6 Turbo Power
of course i changed the rotors. wouldnt be able to use the ad22 calipers w/ stock rotors. ill try adjusting the pedal. thanks again for the responses.
1.6 - The Underdog
153 HP & 152 TQ
Old Feb 8th, 2003, 09:02 PM   #13 (permalink)
Teknokid
Boost anyone?
Teknokid's Avatar
Send a message via AIM to Teknokid Send a message via Yahoo to Teknokid
How much did the setup cost you? Including taking it to a shop to bleed the brakes. I really want to upgrade my brakes. Especially after last night, i almost slammed into a Toyota 4runner, it got me mad cause there was no one in front of her and she hit the brakes really hard. I hate not having ABS.
Chris
My ebay listings
Tekno AutoHaus
Originally Posted by Altim8GA
Does it really matter? That car is so visibly loud, a deaf mute starts to cuss it 2 exits away.
Teknokid is offline   Reply With Quote
Old Feb 11th, 2003, 01:11 AM   #14 (permalink)
AznVirus
1.6 Turbo Power
$520 shipped from Courtesy Nissan in Texas. bleeding the brakes is an easy task, very do-able for the everyday person. just get a one-man brake bleeder kit from an Autozone. if you need to ill write up how to bleed the brakes.
1.6 - The Underdog
153 HP & 152 TQ
Old Feb 11th, 2003, 06:54 PM   #15 (permalink)
PatScottAKA99XE
ex-Super *********
If you want/need ABS the AD's wont help you.
Patrick Scott
