I've tried searching and waiding thru the hits I go on calipers.
I'm not positive I have the correct name so I'll attempt to describe the part.
I bought brake pads for my girlfriends 96 200sx. I removed the right front caliper to replace the pads and couldn't get the new pads in. Yes, I compressed teh caliper piston.
My problem is the top caliper pin. There are two of them. The bolts that hold the calipers on the car go into these pins. Both pins are covered with a seal that expands and contracts as the pins go in and out. I'm assuming they only slowly go in as the pads wear.
Anyway, the lower pin pops right out and is well greased. The top pin is stuck solid.
After toiling with the drivers side for a while I switched to the passenger side. Evrything came apart easily. The caliper pins on this side are well greased and slide out easily.
Now the passenger side has new pads and the drivers side still has the old pads. These old pads are about 1/2 gone. (it wasn't exactly broke. I shouldn't have tried to fix it
So what do I do about the stuck pin? Does that mean I need new calipers? I'm afraid to beat or pound on the caliper to try and get it out. I guess the worst I could do is break the caliper. They I would know to buy another.
Any help or links to proper threads will be apreciated.
