Old May 15th, 2006, 06:07 PM   #1 (permalink)
karayj
Help sloppy front end
I have spent too much money chasing this problem. I have a 96 4x4 pathfinder replace rear shocks because the rear end shimmys when I hit the gas the passenger side rear kicks out to the right and the front drivers side kicks out to the left.
I have also replace the tie rod ends no help I got a used strut right front no help I got a new right trailing arm with new bushings no help I am about to buy new struts and ball joints (lower) but I need your help. The front ends feel like its bottoming out and the steering wheel shakes over all from the bumps what do you think I should do I am lost. I may think worn bushing on the lower controlare becaue the cars pulls to the right I am so lost and I used to be a great part time machanic... I have spent tooooo much money chasing this and driving is not fun on the highway the car wobbles when hitting a small bump also front and rear sway bar links have been replaced.
karayj is offline   Reply With Quote
Old Oct 15th, 2007, 05:37 PM   #2 (permalink)
97pathy518
I have a 97 pathfinder 4x4 4wd, and i have the same problem. I got the struts replaced as of now...and it helped with the front bottoming out and some of the suspension wobble. But the rear shimmy at high speeds is due to a suspension problem in the back.
I heard that this shimmy problem is the rear link (control) arms and bushings... there is a forum (pathfinder problems - Topix) where about 100 people with our exact same car have the exact same problem. You can check that out.
97pathy518 is offline   Reply With Quote
Old Mar 14th, 2008, 05:44 AM   #3 (permalink)
karayj
All set rear trailer arms were bad. Replaced them and the car is great again.
Silvia front end conversion OR 93 240sx front end NEEDED LouderLowerFaster S13 240SX 1989-1994 38 May 28th, 2004 05:04 AM
Parts needed for 89-90 to 91-94 front end conversion? .Whitey. S13 240SX 1989-1994 9 Apr 27th, 2004 02:20 PM
Front end shimmy stevem5000 Truck & SUV 5 Mar 21st, 2004 09:54 PM
Nissan gave the 2004 Sentra the new Max's front end. DropD B15 2000-2006 9 Mar 19th, 2003 02:35 PM
99 front end conversion to spec v??? sentravis B14 95-99 chassis 15 Jul 31st, 2002 10:10 PM
