Originally Posted by wes
No you cannot use your fronts as rears. As for the conversion, search nissanperformancemag.com they have a how-to article on this VERY subject.
Well, if you've got some basic fab skills you can. I made my own front brake setup on my GA16/B13 (1984 Dodge Daytona rotors, 1.375"-piston Wilwood calipers), and therefore I had some spare stock front rotors laying around. I decided to use them on the rear of the car to eliminate the drums. I used the 1" pistoned 4-pot Wilwoods and a custom bracket that bolts to the upright, and welded a bracket in place for a Wilwood spot caliper (for emergency brake), and all was set. I have about $400 spent on (4) rear calipers, and maybe 6 hours of labor to template/fabricate/install the setup on the car.
Bob
