Old May 14th, 2006, 09:43 PM   #1 (permalink)
ASxa86
Front Brake Upgrage/Rear conversion
I'm wanting to get my front brakes upgraded on my 98 sentra and also get my rear drum brakes converted to disk brakes.
My question is.
Can my front disk brakes be used for my rear brakes once i buy the conversion kit? Also, what all needs to be done to get the drum brakes converted to disk? I know I can buy some brackets that will allow me to use disk brakes but I don't know what else needs to be done.
Advice, suggestions, instructions, anything is helpful.
ASxa86 is offline   Reply With Quote
Old May 15th, 2006, 11:46 AM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
No you cannot use your fronts as rears. As for the conversion, search nissanperformancemag.com they have a how-to article on this VERY subject.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old May 15th, 2006, 11:53 AM   #3 (permalink)
RallyBob
Well, if you've got some basic fab skills you can. I made my own front brake setup on my GA16/B13 (1984 Dodge Daytona rotors, 1.375"-piston Wilwood calipers), and therefore I had some spare stock front rotors laying around. I decided to use them on the rear of the car to eliminate the drums. I used the 1" pistoned 4-pot Wilwoods and a custom bracket that bolts to the upright, and welded a bracket in place for a Wilwood spot caliper (for emergency brake), and all was set. I have about $400 spent on (4) rear calipers, and maybe 6 hours of labor to template/fabricate/install the setup on the car.
Bob
RallyBob is offline   Reply With Quote
2004 & 2005 Armada brake problem Shannonop Titan & Armada 11 Aug 5th, 2007 03:33 PM
Brake Drum to Disc Conversion Parker Beach U13 1993-1997 Altima 7 Jan 14th, 2006 01:28 PM
nx big brake conversion gtr_b13 Suspension & Brakes 0 May 19th, 2005 12:44 AM
Silvia front end conversion OR 93 240sx front end NEEDED LouderLowerFaster S13 240SX 1989-1994 38 May 28th, 2004 06:04 AM
REAR BRAKE CONVERSION KITS for drum eqipped B14s NOW AVAILALBE!!! myoung B14 95-99 chassis 18 Feb 6th, 2003 11:18 AM
