make sure you greased up all the proper slides on the calipers and make sure you've got the right metal shims and everything on the back of the pads. if you got drums pop em off and check for brake dust build up. spray it down with brake cleaner and take some sand paper to the drum pads and inside where they touch. any where you see brake dust thats potential noise. also you might want to take a wire wheel and clean up any spot on the caliper where the pads slide and grease any place you can tell there was metal on metal contact.
95 200sx SE- lots of good parts that work equally well as name brand parts that npm advertises. SMOKE TIRES NOT DRUGS!
