Old Oct 11th, 2005, 10:30 PM   #1 (permalink)
sercool
Alignment experts- Need help w/ 200sx
I just had my 200sx/B14 (all stock suspension) alignment adjusted after replacing inner tie rods. I was looking at the spec sheet and this is what they set it at:
LF Camber -.4 deg
RF Camber -1.3 deg
LF Toe .06 deg
RF Toe .14 deg
Is this much difference between the left and right for toe and camber acceptable? Kind of looks to me like they just rushed to get it done. But the toe is the only adjustable setting w/ a stock suspension, correct?
Also in the rear the specs are:
LR Toe .29 deg
RR Toe -.12 deg
I know this is out of spec, is there anyway to correct it besides beam bending? Will the way the toe is in the back cause trouble as it is? Thanks for any help.
sercool is offline   Reply With Quote
Old Oct 12th, 2005, 03:49 PM   #2 (permalink)
thestunts200sx
Nissan Addict
I dont know to much about the front.
Your right about the rear and beam bending. There's a guy they did the project 200sx on I think who is like the only one ot get it right.....
http://www.nissanperformancemag.com/...01/westend.php
TheStunts200sx
People that owe me money and/are SCAMS::
R1autodesignwholesale
thestunts200sx is offline   Reply With Quote
Old Oct 13th, 2005, 10:52 AM   #3 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
LF Camber -.4 deg
RF Camber -1.3 deg
LF Toe .06 deg
RF Toe .14 deg
LR Toe .29 deg
RR Toe -.12 deg
I don't have the FSM in front of me (was going to check it last night when I got home and I forgot), but if I remember correctly the front camber is barely within spec. Don't worry about the front toe. Despite what it looks like on paper they have it pretty close (both sides are a little on the toe out side of things, but it's still within spec). I donno about the rear though. That looks a bit off, but I'll have to check the FSM.
You are correct in thinking that front toe is the only adjustable alignment element on our cars. The front camber could be the result of worn bushings, sagging springs, worn wheel bearings, or a slightly bent frame, so checking/fixing those things will put the camber back in line.
Captain Slow.
Old Oct 13th, 2005, 11:26 PM   #4 (permalink)
98sr20ve
Nissan Fanatic
Send a message via AIM to 98sr20ve
I am sure he has toe in not toe out. Toe out is way beyond factor spec. Also, he probably has a tweeked frame or the machine is off as far as the camber is concerned. Both the left side measurements are off and they should never really change much. I would want to see if his wheels are straight as well or if they adjusted for that at all.
92 240SX Project Car.
98sr20ve is offline   Reply With Quote
Old Oct 14th, 2005, 11:57 AM   #5 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
The acceptable range for front toe given in the B14 FSM is 0 to 0.4 deg toe in on each side. The "nominal" figure they give is 0.2 deg toe in for each front wheel.
What I meant was that his numbers for toe indicate less toe-in than the "nominal" figure, but are still within spec.
Sorry for the confusion.
Captain Slow.
Old Oct 14th, 2005, 02:27 PM   #6 (permalink)
sercool
Well the toe numbers are just as the ones the guy gave me on the print out sheet that I asked for. They could be off as much as they are since the car was run into twice about 8 yrs ago. But that was supposed to be corrected.
The only other thing that I could see making the measurements off in the back is that the 2 tires were previously on the front and had pretty bad wear due to the inner tie rods being shot. Not sure if that would make a difference in how they measure it though.
Tires and Alignment Nismo1997 Suspension & Brakes 0 Apr 22nd, 2005 10:27 PM
Alignment problems? c.castillo Titan & Armada 1 Apr 12th, 2005 09:57 AM
alignment shop phreako Dallas Nissan Enthusiasts 17 Apr 13th, 2004 09:36 AM
Front Alignment Questions jadcock Truck & SUV 7 Oct 29th, 2003 04:31 PM
funny convo!.. hope you... Niss200SXGTR Off Topic 6 Jul 4th, 2002 01:18 AM
