clicking sound comming from front left tire when in reverse! - Nissan Forum
post #1 of 9 Old Aug 27th, 2005, 07:16 AM Thread Starter
I just noticed this loud clicking sound coming from the drivers side of my nissan 200 sx. It is only when I am in reverse. Any ideas as to what it could be?
robzgrl1 is offline
post #2 of 9 Old Aug 28th, 2005, 01:00 PM
Boxed Fox
ReVerm's Avatar
Are you sure it's front front left? And do you have drum brakes in the rear?
Captain Slow.
ReVerm is offline
post #3 of 9 Old Aug 29th, 2005, 07:14 AM Thread Starter
No I don't but I just replaced the back brakes and yes they are drums. It started out as a real quiet clicking then I was backing out of my drive way and it was loud. It is an stick to I thought it might have something to do with the clutch but Not sure. Clueless. any help would be appreciated.
robzgrl1 is offline
post #4 of 9 Old Aug 29th, 2005, 07:22 AM
Boxed Fox
ReVerm's Avatar
Ok. You may want to check the rear drums. Drum brakes usually have an adjuster mechanism that only activates when you are driving in reverse. Sometimes something can come loose and start to click (for example, the rear drums on our cars have a sprocket and lever arm assembly near the top. If the lever arm comes off the sprocket completely, the lever arm will move freely and will start to click). It may also be the case that the drum brakes need a little grease (at certain points, not all over. Check the Haynes manual or Factory Service Manual on where to lubricate).
Good luck.
Captain Slow.
ReVerm is offline
post #5 of 9 Old Aug 29th, 2005, 05:01 PM
TwiztidKidd
Twiz's Avatar
It's your left (driver's side) drive axle. You can quickly tell just by inspecting the rubber boot to see if it's torn and most likely you'll notice that most of the grease has left the boot and your wheel assembly has grease all over. I had the same exact problem. My opinion: don't fix the rubber boot... have the drive axle replaced.
Twiz is offline
post #6 of 9 Old Aug 30th, 2005, 01:41 PM Thread Starter
Even though It is only when I am driving in reverse? I just had a NEW control arm and struts put on the front end a few months ago!!!! Could it possibly be anything else? Do you know about how much that runs to repair? Thanks
robzgrl1 is offline
post #7 of 9 Old Aug 30th, 2005, 04:23 PM
TwiztidKidd
Twiz's Avatar
The drive axle itself will cost you somewhere around $60 to $80 prolly a little bit more if your car has ABS. Mine was $64 and $30 core charge which you get back once you return the crappy axle. I replaced it myself so I have no idea how much a mechanic would charge... prolly anywhere from $100 to $200 just for the labor.
You'll notice that the clicking noise gets even louder when you turn the steering wheel while driving in reverse.
You should run a few more tests including the visual one I mentioned in my previous post, before you have it replaced.
Twiz is offline
post #8 of 9 Old Sep 6th, 2005, 02:29 PM
I replaced myne sunday and it was 54.99 40$ core
90, b-12 xe
racecargo11 is offline
post #9 of 9 Old Oct 4th, 2005, 06:43 PM Thread Starter
The problem doesn't happen when the car rolls backwards in nuetral. We also had a brake specialist look at it and they are claiming it is something in the transmission.
robzgrl1 is offline
  Nissan Forum > Technical > Suspension & Brakes
Gear in this thread - nissan Tire by PriceGrabber.com
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Wierd clicking sound under dash... mmdb General 240SX/Silvia/S12 200SX 3 Jun 30th, 2006 06:07 PM
??????clicking sound in front???????? nyit240 B11/B12/KN13 82-90 chassis 21 Jun 23rd, 2006 12:18 AM
weird sound in front end krusty General Altima/Stanza discussion 1 Jul 3rd, 2004 02:42 PM
Front Sound Noise LoveNissan Suspension & Brakes 1 May 24th, 2004 09:55 PM
clicking sound when driving Javon B13 91-94 chassis 2 Apr 21st, 2003 08:38 AM
You may post new threads
You may post replies
BB code is On
