Old Dec 3rd, 2002, 05:28 PM   #1 (permalink)
NXtremese-r
Send a message via AIM to NXtremese-r
SS brake line problem
well, the other day i noticed that the plastic sleeve on my SS line going to my rear pasengerside caliper has slid up the line, causing the line to come loose from the banjo bolt, leaking fluid. the hose is loose and can spin around ,but it doesnt look like its going t ocome off. i pulled on it a little. i put some JB wled on it to keep it from coming apart some more and i have bought an OEM replacement line for the fix.
anyone else have this problem? has anyone had to buy a kit for just a couple of hoses and have one of the back SS lines laying around, or even a front one for that matter - i think it will fit, as far as i know they are all the same size.
this really pisses me off..i would have thought that SS lines (taken care of properly) would almost outlast the car! i have only had them on there for like a year and half to two years. I have a friend that has a 91 with stock UNREPLACED rubber lines!
Alex
'93 NX2k
Alex
'93 NX2k w/work
'06 350Z w/no work
NXtremese-r is offline   Reply With Quote
Old Dec 4th, 2002, 03:58 PM   #2 (permalink)
boost_boy
CA18DET Wizard
boost_boy's Avatar
Send a message via AIM to boost_boy
What name brand of hose you used so that the rest of us can stay away from it!
You must pay to play! Boost ain't cheap! {x2 B12 Sentras with CA18DET engines}.
boost_boy
boost_boy is offline   Reply With Quote
Old Dec 4th, 2002, 05:29 PM   #3 (permalink)
NXtremese-r
goodridge
Alex
'93 NX2k w/work
'06 350Z w/no work
Old Dec 4th, 2002, 05:38 PM   #4 (permalink)
boost_boy
CA18DET Wizard
boost_boy's Avatar
You're not the first one that has complained about leakage from their hoses.
boost_boy
Old Dec 4th, 2002, 05:40 PM   #5 (permalink)
NXtremese-r
well, i havnt heard of anyone else making SS lines B13's
Alex
'93 NX2k w/work
'06 350Z w/no work
Old Dec 4th, 2002, 05:56 PM   #6 (permalink)
boost_boy
CA18DET Wizard
boost_boy's Avatar
I bought some for the NX2000 as I have both the front and rear brake set-up as well as the brake booster on my B12. However, I can't find the name of the internet company I purchased them from. They have a steel braid as well as a red rubberized coating over the steel. If I find the company, I'll definitely share it with you.
boost_boy
Old Dec 4th, 2002, 06:01 PM   #7 (permalink)
NXtremese-r
that would be great. do you remember what you paid for them? i think that would be an awsome setup with that rubber coating.
Alex
'93 NX2k w/work
'06 350Z w/no work
Old Dec 4th, 2002, 06:14 PM   #8 (permalink)
boost_boy
CA18DET Wizard
boost_boy's Avatar
Like $119.00!
boost_boy
Old Dec 4th, 2002, 06:15 PM   #9 (permalink)
NXtremese-r
wow, thats about the same price as the goodridge lines! yea, i really need these now!
Alex
'93 NX2k w/work
'06 350Z w/no work
Old Dec 5th, 2002, 01:39 PM   #10 (permalink)
Hawaii_SE-R
Nissan Fanatic
Hawaii_SE-R's Avatar
Location: Stuck on a Rock in the middle of the Pacific Ocean.
Got my set from SMC Products (626-355-3763) about 2 years ago. Not sure if they are still around though. They made a good bunch of stuff for Mike K's USCC SE-R: http://www.se-r.net/about/200sx/scc/feb99/
http://www.serca.org/hawaii/DCs_sig.jpg
1991 Aztec Red SE-R: JWT ECU, S3 Cams, PP, Motor Mounts; Stillen STB, Intake; Hotshot Header, CAI; UR 3 Pulley set; Custom exhaust w/ Sebring muffler; Eibach Prokits Springs & Roadhandler Struts?; Random Thoughts Rear STB; Magnecor wires; AMSOil; AD22VF brakes; Metal Master pads; Ford High-Performance Synthetic brake fluid; SMC SS brake lines; LoTek A-pillar Gauge Pod w/Autometer gauges; Techtom MDM-100; B14 SE-R rims w/ S0-3s; Tsuru headlights w/Silverstars; Hella FF50 Driving Lights; N-Tech Subframe connector; Baker Precision Silicone radiator hoses; NX center counsol
1991 Vail White SE-R: K&N drop-in air filter, oil filter and a lot of AMSOil
Parts on the side: Unopened ES Bushing Master Set; Unopened SMC Short Shifter; Used GC coilover set; New ZEX/Compcams ultra-light flywheel; Used SS Nakayama muffler
Hawaii_SE-R is offline   Reply With Quote
Old Dec 7th, 2002, 05:33 AM   #11 (permalink)
aztecred92
aztecred92's Avatar
Send a message via AIM to aztecred92
Exclamation
Greg Vogel at Mossy Nissan just got some S.S. brake lines made for our cars. I just ordered a set for my '92 SE-R. Supposed to be better made than Goodridge and SMC. Each set are individually tested! I'll follow up with more info once I get mine in.
aztecred92
aztecred92 is offline   Reply With Quote
Old Dec 12th, 2002, 08:50 PM   #12 (permalink)
911AS
Posts: n/a
I hear that techna-fit do better SS lines than Goodridge but i cannot confirm.
Techna-Fit : 1991-93 NX COUPE 4 NIS-1420 $115.00
Website: http://www.techna-fit.com/nissan.html
I hope that help.
Dammit! I just bought Goodridge SS lines just before the group buy for the SMC brakes lines was made. And it seem people have problem after 1 year or 2 later(Goodridge). I don't install them yet thats a scared that they will eventually brokes!
Old Dec 13th, 2002, 01:12 AM   #13 (permalink)
NXtremese-r
thanks for the link. i have a couple of options open. one of them is to go to a hydrolic machine shop that woul make lines for trucks and stuff and have them make one in house, shouldnt take to long either.
Alex
'93 NX2k w/work
'06 350Z w/no work
Old Dec 13th, 2002, 02:51 AM   #14 (permalink)
altimate94
altimate94's Avatar
so, are SS lines really worth it.........ive been thinking of getting them for my U13 Altima......................
-Robb-
SHIFT_team_nyc
LIQUID-INK.COM for all of your modification needs
BLINK SOUNDWORKS For all of your audio/visual needs
WWW.XTCDYNAMICS.COM XTC Dynamics "It's Worth the Trip!"
WWW.IMPORTFANATIX.COM Import FanatiX "High Revin', Low Ridin'"
altimate94 is offline   Reply With Quote
Old Dec 13th, 2002, 09:47 AM   #15 (permalink)
NXtremese-r
if your going to take the altima to the track, and/ or are going to be running it where you are going to be using a lot of braking, yes. besides, if you get a good pair, they should last longer then stock.... :-)
Alex
'93 NX2k w/work
'06 350Z w/no work
