Originally posted by Hawaii_SE-R
SS Brake Lines help reduce the mushy feel of brakes while increasing the response time from pedal to pads regardless of whether you are at a track or doing daily driving.
But is it worth to install SS lines for street driving? Can you feel difference? Do the rubber lines flex that much?
However, if you plan to hit the tracks (road course), the more important items are the rotors, calipurs, pads, and brake fluid.
True! Brake pads and break oil should be the first thing to change.
Brake lines will not do anything to reduce brake fade.
I understand and agree that they don't do nothing for brake fading. But, into racing condition, the rubber lines expand more than street driving because they substain a lot more of heat. To compensate, you must push the brake pedal a little more further. So from the driver perspective is it like brake fading?
