Old Jul 25th, 2005, 06:35 AM   #1 (permalink)
ASG
Re-Using Coil Springs --- B13
Hey Everyone,
I have some Monroe Sensa-Trac struts on the rear of my 93 Sentra XE. The struts were installed about 15k-20k miles ago. The car has 94k miles on it now.
Lately, I noticed that the rear wheels (15-inch rims) are rubbing against the fender when going over certain inclines in the road (like turning from the street into a parking lot).
I want to replace all the struts with the KYB GR-2's. How can I tell if the coil springs are bad? I only want a factory ride, so can I re-use the coil springs with the GR-2's?
Thank you.
ASG
ASG is offline   Reply With Quote
Old Jul 26th, 2005, 10:10 AM   #2 (permalink)
pete?
Banned
pete?'s Avatar
Send a message via AIM to pete?
if you want 100% factory ride the gr-2's are not 100% the same. they are a tad stiffer but with the stock spring rates and the gr-2's you car will handle very nicely for a stocker. the way to tell if your springs are sagging is this. when you remove them from the strut measure them and compair ot measurement to stock. also, measure your ride height right now and compair it to stock, if either of these are off you may want to replace the springs.
FYI, if you need to replace one its a good idea to replace all of them
pete? is offline   Reply With Quote
Hyperco B13 Springs - Round FOUR! SR20AL Group Buys 3 Mar 29th, 2005 09:56 AM
Megan Racing Springs b13 Shift1.6 Suspension & Brakes 1 Jan 23rd, 2005 03:43 PM
B13 se-r springs sentrapower93 Suspension & Brakes 4 Apr 6th, 2004 10:04 PM
B13 front OEM springs Andro Suspension & Brakes 2 Feb 10th, 2004 11:12 PM
The *best* B13 springs are here! chriscar Group Buys 11 Feb 25th, 2003 11:20 PM
