Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > SR20DE/DET Engines
SR20DE/DET Engines 1991-2002 Silvia
Old Jul 10th, 2005, 12:17 AM   #1 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
Send a message via AIM to trmn8r
OIL OIL Every Where Please Help!
I Recently replaced the gaskets on my turbo. well when i put the parts back on i start driving around. well i noticed a big puddle of oil on my freinds drive way. so I pop the hood and i see no sign. then i turn on the car and take a look and i see oil squirting out of the oil line that goes to my turbo. (oil commin out of the block). well i go and try to tighten the bolt. comes out that the sun of a bitch is striped. now my car is stranded. does any one know of any solutions in fixing the striped threads on the engine block. someone please help
trmn8r is offline   Reply With Quote
Old Jul 10th, 2005, 08:31 PM   #2 (permalink)
rogoman
Keeping the peace
rogoman's Avatar
Find out the size of the fitting and get a HeliCoil rethreading kit.
Old Jul 19th, 2005, 06:34 PM   #3 (permalink)
BlandAnalogy
yea you might have to drill it out and re tap it. next time use a torque wrench and go with specs
BlandAnalogy is offline   Reply With Quote
Old Jul 20th, 2005, 11:01 AM   #4 (permalink)
luka
ouch.. stripped thread on the block it'll never be the same heh, consider that your achiellies heel now.
luka is offline   Reply With Quote
Old Jul 20th, 2005, 12:55 PM   #5 (permalink)
BlandAnalogy
naw it'll be good if he does the job right. i had to re thread a whole block a while back using a tap and die set. it turned out great. you just need the right equipment. you'll need plastic garbage bags, tap and die set, masking tape, an engine stand and a speed wrench. compressed air would help too.
Old Jul 20th, 2005, 04:29 PM   #6 (permalink)
Darkside180sx
Darkside180sx's Avatar
Send a message via AIM to Darkside180sx
Same thing happend to me when i droped my motor in. I had to put a heil coil in and it is a 12mmx1.25. just get the kit and youll have to get a drill bit too(31/64). just be carefull when your drilling the hole! its pretty easy but make sure you have room for the drill. good luck.
Darkside180sx is offline   Reply With Quote
Old Jul 21st, 2005, 11:47 AM   #7 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
thanx you guys i wasnt able to sleep for the past week 1/2 thinking about this shit. at least i found out da prob before i started driving the son of a gun.
Best Engine Oil???? MCHNHED B14 95-99 chassis 70 May 15th, 2008 06:21 PM
Changing Oil types ace B13 91-94 chassis 18 May 6th, 2006 11:10 PM
Limited time showing, come one come all!! Marvin Off Topic 43 Jan 14th, 2005 08:35 PM
Checking Engine Oil - Too High? Josh GA16DE 1.6L Engine 10 Aug 10th, 2004 06:23 PM
Changing Oil GlowstickBoy Off Topic 5 Aug 8th, 2002 12:07 PM
