Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > SR20DE/DET Engines
SR20DE/DET Engines 1991-2002 Silvia
Old Sep 30th, 2004, 01:01 PM   #1 (permalink)
Darkside180sx
Darkside180sx's Avatar
Send a message via AIM to Darkside180sx
Exclamation Help! To much fuel!
i have just completed the sr swap into my 91 240sx. But i have one problem every time i start the it it runs fine for about 3 mins and then it starts missing. Almost like its getting to much fuel. So i cut it off and take out the spark plugs.(gaped at .030) The spark plugs are soaked with gas and the the top of the pistons are soaked too. I have checked my lines going to the fuel rail and fuel preasure regulator and they are all correct. Any ideas would be greatly appreciated.
Thanks,
Ryan
Darkside180sx is offline   Reply With Quote
Old Oct 11th, 2004, 11:23 AM   #2 (permalink)
zellx2004
Nismophiliac
zellx2004's Avatar
Send a message via AIM to zellx2004 Send a message via Yahoo to zellx2004
I'm not totally sure on this one, but you may want to check your MAF, and try to gap the plugs a little more. (say .035-.036??).
zellx2004 is offline   Reply With Quote
Old Oct 30th, 2004, 02:46 PM   #3 (permalink)
AlexAtMyNismo
AlexAtMyNismo's Avatar
Send a message via AIM to AlexAtMyNismo
borrow someones air/fuel gauge or buy one and see what the heck is goin on with the readings..... or get an Apexi SAFC and you can adjust the settings yourself.....
-Alex B.
PERFORMANCE NISSAN
AIM: NeedsMoSpeed
MyNismo.com :thumbup:
Nissan Tuner Parts Solution
AlexAtMyNismo is offline   Reply With Quote
Old Oct 31st, 2004, 09:13 AM   #4 (permalink)
Darkside180sx
I figured it out... It was my safc II...the signal wire from the maf sensor was wired in wrong to the safc II...so therefor the ecu wasnt getting a signal and went into pig rich cause it wasnt getting a signal.
fuel and wiring problem with se-r, pics included john 85 B13 91-94 chassis 4 Jul 26th, 2004 11:28 PM
Fuel Pressure Regulator 0341TODD Z31 300ZX(T) 16 Jun 29th, 2004 08:10 AM
SPECS to Compare Compacts sentravis B14 95-99 chassis 3 Oct 26th, 2003 08:52 PM
New recall on Fuel Pump for 2002-2003 Altima PhilGood L31 2002 - 2006 7 Aug 30th, 2003 09:53 AM
Installing 300zx Fuel Pump into a B14 holy200sx GA16DE 1.6L Engine 10 Jul 2nd, 2003 03:33 PM
