Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > SR20DE/DET Engines
SR20DE/DET Engines 1991-2002 Silvia
Old Aug 28th, 2002, 01:01 PM   #1 (permalink)
SE-Rial killer
Posts: n/a
S14 Det Problems Again!
OK SHEs in shes beautiful but she won't start on her own! We finally got the S13 DET in the S14 completely.. bumpers back on with the intercooler mounted etc etc etc. We can get it to run if we use a little bit of ether on start up. She will run and hold idle at about 1500. THe only problem is when we step on the gas the rpms go up and then come down to the point that the car is going die! Plus the car won't run over 4500 RPM.. Which we think we might have solved with the MAF wire. We haven't gotten a chance to try it out! Just so you know the fuel pressure we cannot check without a guage but when you pinch the hose upon start up there is plenty of pressure. There is spark, the injectors are ticking away, new plugs, running out of ideas... Battery turns over just fine along with the starter! HELP HELP
Old Sep 4th, 2002, 02:13 AM   #2 (permalink)
terry dibler
terry dibler's Avatar
sounds like either ignition or it might have jump time
95 maxima: k&n
72 chevy truck:lowered 4'' in front & 6'' in the rear,vortec heads ,msd ign,muncie m22 rock crusher
terry dibler is offline   Reply With Quote
Old Sep 4th, 2002, 12:52 PM   #3 (permalink)
SE-Rial killer
Posts: n/a
We found out that it was the MAF wire we extended... DOn't ever extend the MAF wire while the ECU is hooked up! DUMASS! Now the Ecu is fried.... and it won't rev past 2500 because the ecu is cutting fuel. so we eliminated that problem!
S14 DET vs. S15 DET KingEkstacy SR20DE/DET Engines 19 Dec 12th, 2006 09:03 PM
EASY DET swap......possible? BIGBULS Forced Induction & Nitrous Oxide 10 Dec 21st, 2002 02:02 AM
Any problems with swaping an DET? SR20Sentra98 S13 240SX 1989-1994 6 Sep 6th, 2002 12:41 AM
Questions about DET installing in a S14 SE-Rial killer SR20DE/DET Engines 1 Sep 1st, 2002 06:18 PM
Common Problems with Det swap into se-r sr21lbmonster SR-Series Engines (DE/VE) 0 Jun 20th, 2002 09:22 AM
