Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > SR20DE/DET Engines
SR20DE/DET Engines 1991-2002 Silvia
Old Oct 25th, 2003, 11:28 AM   #1 (permalink)
winter_sean
MAF sensor problem?
So I've got my red-top all installed in my car ('93 240sx) and it runs - sounds good too, but when I hook up the MAF sensor, it cuts out. The MAF I'm using is my stock KA24DE sensor from my old engine. Does the MAF need to be re-wired?. From what I understand the KA24 MAF should be fine unless I push it beyond 300hp or so. Do I need to get another MAF or am I missing something?
winter_sean is offline   Reply With Quote
Old Oct 26th, 2003, 03:29 AM   #2 (permalink)
180SX-X
Nissan Addict
180SX-X's Avatar
where the hell is your SR MAF?!?! make lyfe easy, get an SR MAF.
180SX-X is offline   Reply With Quote
Old Oct 26th, 2003, 08:17 AM   #3 (permalink)
winter_sean
Thumbs up
I got a red-top sr20det engine, but it didn't come with the MAF. So you think getting an sr MAF would be the best? I see a lot of people put the z32 MAFs on their cars, but I can't find anything about how to rewire one of those. Also somebody said something about ECU re-mapping? if you're going to use the stock sr ECU with the z32 MAF. You're probably right, go with the sr MAF...
Old Oct 26th, 2003, 12:36 PM   #4 (permalink)
vsp3c
Banned
vsp3c's Avatar
Send a message via AIM to vsp3c
sr maf is limited to about 250hp. keep that in mind
vsp3c is offline   Reply With Quote
Old Oct 26th, 2003, 01:02 PM   #5 (permalink)
winter_sean
well I'm already above that I think. So what's the next best choice - a 90-6 z32 maf?
Old Oct 26th, 2003, 01:41 PM   #6 (permalink)
vsp3c
Banned
vsp3c's Avatar
i think the reason why so many ppl use z32 mafs is because they can handle lots of power, aren't as hard to find (as sr mafs), and have lots of aftermarket support.
i would recommend the z32 maf but i do not know anything about how to rewire those or whether or not you would have to map the ecu.. i'll try to find out for you
Old Oct 26th, 2003, 04:21 PM   #7 (permalink)
winter_sean
Thanks, I'd appreciate that. I think I've found some good wiring info, but i'm not sure about re-mapping either.
Old Oct 26th, 2003, 07:45 PM   #8 (permalink)
vsp3c
Banned
vsp3c's Avatar
i haven't found any info on the wiring but i have found that you do have to remap the ecu. a shop familiar with nissan tuning should do it without any problem (preferably one familiar with sr20's)
Old Oct 26th, 2003, 11:31 PM   #9 (permalink)
180SX-X
Nissan Addict
180SX-X's Avatar
you can call up JWT cause they noe all about nissan ecu's and they sell Z32 ecus.
Old Nov 9th, 2003, 04:35 PM   #10 (permalink)
warneck
warneck is offline   Reply With Quote
Old Nov 9th, 2003, 07:42 PM   #11 (permalink)
vsp3c
Banned
vsp3c's Avatar
http://srswap.com/html/info/faq_mafs.htm
just another one..
Old Nov 12th, 2003, 08:29 PM   #12 (permalink)
JayLew
One Wheel Drive
Save yourself some money. Buy a stock SR MAF.
The Z32 upgrade will cost you atleast $600.00
The Z32 MAF is atleast $100, and a JWT ECU upgrade is atleast another $500.00.
Not worth it unless your READY to produce over 300hp.
Jason
1996 200sx SE-R
1992 240sx coupe (5 lug w/Z32 rims)
JayLew is offline   Reply With Quote
Old Nov 12th, 2003, 08:39 PM   #13 (permalink)
BlueBOB
The Hair of BOOM!
BlueBOB's Avatar
Send a message via ICQ to BlueBOB Send a message via AIM to BlueBOB Send a message via MSN to BlueBOB Send a message via Yahoo to BlueBOB
nice graphic there warneck...
I'm just a big bang Baller On a Budget...
Cardomain : Dallas Nissan Enthusiasts : DNE Forums : VQPower.com - DTM
BlueBOB is offline   Reply With Quote
Old Nov 13th, 2003, 09:05 AM   #14 (permalink)
winter_sean
yeah, that's what I've done. I plan to be over 300hp next year with a couple other tweaks. Do you have to send your chip to JWT. Couldn't a dealership remap the ECU if all you're doing is changing the MAF?
Old Nov 13th, 2003, 09:28 AM   #15 (permalink)
BlueBOB
The Hair of BOOM!
BlueBOB's Avatar
nope because you can't just "reprogram" it.
JWT solders on daughter boards onto the ECU. they have to physically modify it as well because nissan ECU's are designed to reset themselves each time the car is turned off and on and a full reset when a power loss occurs. they retain very little info. that's why a lot of cars in the nissan family with timing controlled by the ECU can't advance their timing... the ECU will forget the setting once the car is turned off
