Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > SR20DE/DET Engines
SR20DE/DET Engines 1991-2002 Silvia
Old Jan 20th, 2008, 11:47 PM   #1 (permalink)
mvnixon
Angry SR20DET randomly cutting out PLEASE HELP!!!!!!!
Hey Everyone I have a huge problem that I have talked to many people about and I can not seem to find a solution.
My red top sr20det is randomly cutting out when I am driving it. The car still runs when it happens, it just acts like the throttle is at 0% when I am pushing it down. Then just as quickly as it happened it will return to perfectly normal driving. It happens very randomly and there is no consistent pattern to it. At times it seems when I drive the car aggressively it happens more often.
If anyone has any input I would greatly appreciate it. I have checked the TPS and it seems to be working within range. I have a new Z32 MAF and a Greddy E manage blue supporting it all. There is nothing crazy done to the car, it has a G2871R and supporting bolt ons. Other than this problem the car runs like a dream. Please help if you can!!!!
-Matt
mvnixon is offline   Reply With Quote
Old Jan 21st, 2008, 10:54 AM   #2 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
Send a message via AIM to trmn8r
-Matt
check your coil pack connectors they might be loose. had a problem kinda like that once.
are you sure the tps is ok. did you check the voltage on it when you move it?
it sound like your flat spoting kinda like with carbeurators when theyre not tweeked right.
Quote of the Day From Our Shop "Quick, ill wiggle it while you tug on it"
trmn8r is offline   Reply With Quote
Old Jan 21st, 2008, 11:04 AM   #3 (permalink)
mvnixon
Thanks for the response, I will double check the coil packs, I did check the voltage on the tps as I moved it around and everything tested OK. I was thinking dead spot, but after the test I ruled it out. I might just buy a new TPS and see if that solves the problem... Thanks for the reply if any else has any input I would greatly appreciate it!
Old Jan 21st, 2008, 07:54 PM   #4 (permalink)
ckykm
Nissan Fanatic
also check if your battery connection is loose
happened to me driving on some bumpy roads, the car would turn off then back on real quick
ckykm is offline   Reply With Quote
Old Jan 22nd, 2008, 08:08 AM   #5 (permalink)
rogoman
Super Moderator
rogoman's Avatar
Also make sure the fuel filter has been replaced and check the fuel pump electrical connections.
whats the differences in these sr20det? Se-riously2fast General Discussion 2 Apr 28th, 2006 01:48 AM
sr20det vs. sr20det (bluebird) 240speeddreams S13 240SX 1989-1994 7 Feb 21st, 2006 06:19 AM
SR20DET...why not KA24DE(T) drift240sxdragqueen S13 240SX 1989-1994 32 Mar 25th, 2005 07:04 PM
HELP: DIFFERENCES BETWEEN SR20DET ENGINES? MYTHOS General 240SX/Silvia/S12 200SX 3 Jan 26th, 2005 05:48 PM
geez...another sr20det gti-r thread...but hey...gimme a sec SonsofWisdom SR20DE/DET Engines 7 Oct 13th, 2004 06:04 PM
