Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > SR20DE/DET Engines
SR20DE/DET Engines 1991-2002 Silvia
Old Nov 20th, 2006, 02:35 AM   #1 (permalink)
Alonzo
Alonzo's Avatar
Engine Loses Power
Hi, im new to here,
came here mainly becouse of this problem, hoping to stay for more..
the vehicle is a 96 S14 SR20DET 240SX, car has done around 60K miles, half of them with this engine and turbo.
quite a few mods, most relevent are Greddy E-01 boost conroller, low boost is set to 0.7Bar, that is how i drive it daily, apexi induction kit, cold NGK iridium plugs, XS power EQUAL TUBULAR MANIFOLD, hks exhaust+catback, apexi torbo downpipe.
a few nights ago i stared the car up and knew something was wrong, simptomes:
-car sounds strange more like a boxer engine
-revs arn't steady while idlle, between 800~1000 (usually steady on 900)
-car lost allot of power on low revs so its tuff to get it off the line!
-when the turbo kicks in (stock BTW) it boosts up but cant keep a steady boost, it sounds and goes awefull
-car dosnt overheat, no warning lights...
plz help...
10x in advance
Alonzo is offline   Reply With Quote
Old Nov 20th, 2006, 06:14 PM   #2 (permalink)
slows14a
Hey I got a few questions for ya
1. Who did the mods? You or a shop?
2. How long ago were the mods done?
3. Was your car running well since that time?
First things first- I would check the basics
4. Does your ECU have any error codes? (if you don't know how to check this.. search. There are lots of threads on this)
5. Are you getting spark on all 4 cylinders? Sounds as though you have a miss.
slows14a is offline   Reply With Quote
Old Nov 21st, 2006, 04:14 AM   #3 (permalink)
Alonzo
Alonzo's Avatar
mods were done in a very respectable shop, about 6 months ago,
the car runs bad since it first happend...
if there's a missfire why wont the turbo keep a steady boost?
searched for checking the ecu codes...didnt find anything related to my car
can you please direct me to it?
thanks allot...
Old Nov 21st, 2006, 06:44 PM   #4 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
Send a message via AIM to trmn8r
check you intercooler piping it might be loose. if thats all ok you might have a bad bov. but make sure you pinpoint test starting at the intercooler piping
Quote of the Day From Our Shop "Quick, ill wiggle it while you tug on it"
trmn8r is offline   Reply With Quote
Old Nov 21st, 2006, 07:05 PM   #5 (permalink)
slows14a
You may be dealing with more than one problem, so the first thing is to check ECU codes.
You can check out a procedure here http://forums.********.com/zerothread/60332 that will work for your car. Basically you find the consult port kind of looks like ======= plug and it should be behind the drivers side kick panel opening (where your fuses are). It will be at the bottom somewhere. Turn your key on (but engine OFF) and bridge the two pins on the far left of the bottom row ie. _ _ ===== for two seconds. I use a paperclip in a U shape to do this. When you remove the paperclip etc and look at your dash, the engine light should be flashing a code as per the link above. You can read your codes to see what may be the problem. After you have read your codes, just turn the key off for about seconds and when you turn it back to the on position, you will be in normal operating mode.
If your boost is moving around, you may be dealing with an electrical problem on your electronic boost controller. Are you using the stock wastegate actuator? Try just connecting your boost line directly to the wastegate actuator (ie bypass your boost controller altogether) to see what boost it lets you run, and to see if that solves your boost fluctuation problem. If so I'd check all the vacuum lines to and from your controller and then adjust your controller. How does your boost level fluctuate?
For how long after you had the mods done by the shop was your car running well?
If your car sounds like its missing at idle, do a power balance test by idling your engine, and unplugging the coil harness to each spark plug one at a time to see which one doesn't make a difference to idle speed when you disconnect it.
Old Nov 21st, 2006, 07:10 PM   #6 (permalink)
slows14a
******** = n i c o c l u b (without spaces)
Old Nov 22nd, 2006, 08:48 AM   #7 (permalink)
Alonzo
Alonzo's Avatar
not really sure which pins to bridge,
added some photos:
fuse box :
fuse panel itself (which fuses to bridge) :
maybe you can explane it better on the photo itself...
already turned the boost controller off, same problem...
car was runing strong for 6 months or so...
trmn8r - engine bay looks ok...
thanks allot
Old Nov 22nd, 2006, 06:30 PM   #8 (permalink)
slows14a
Ok alonzo you have taken photos of the area involved.. excellent.
Unfortunately I am not near my car or my digital camera. Anyway the connector you want is the gray one in your first photo.. its the one on the far left of the pic which is above all your fuses.
Here is a pic from the FSM showing the CHK and IGN pins.
Here are the pins on your car (I have highlighted in yellow) you can see the pins are in 3 clusters of 4 (2 x 2) and then 2 pins by themselves on the end.
How are you measuring boost? If you are just getting a reading from the E-01 I would double check with a mechanical gauge. When you turn off the boost controller, does it fully close the solenoid valve? If you are not 100% on that I would run a direct line from boost to the wastegate actuator (ie no tee off at all). I would also check the operation of the wastegate itself by removing the hose from the actuator to the boost controller and hooking it up to a hand held bicycle pump (preferably with a gauge). You want to see that it can hold the same position when you stop pumping it. The maximum pressure you should give it is 44kpa (6psi), and by this stage it should be close to fully open. It should move smoothly throughout its full range too. To check for binding/sticking, when the engine is cold try moving the wastegate flapper by hand.
Is the engine missing at idle? if so do a power balance check as I posted above.
But before you do anything, check your ECU codes...
cheers
slows14a
Old Nov 27th, 2006, 01:33 AM   #9 (permalink)
Alonzo
Alonzo's Avatar
sory for the delay, been abroad...
it came out code no 55...
which dosnt tell me much, or does it?
thanks allot...
Old Nov 27th, 2006, 03:36 PM   #10 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
55 means no malfunction
Old Nov 28th, 2006, 12:54 AM   #11 (permalink)
Alonzo
Alonzo's Avatar
thanks for all the help, seems ill be going to garage after all...
Old Nov 28th, 2006, 05:41 PM   #12 (permalink)
slows14a
There could be other error codes on your ecu (only able to be read by a workshop with vehicle diagnostics computers) which are not on the list of error codes I linked to in a previous post but before going to a workshop I would:
1. Check the wastegate flapper moves ok.
2. Do a power balance test.
If you do take it to the garage let us know what they find.
Old Dec 20th, 2006, 01:20 PM   #13 (permalink)
Alonzo
Alonzo's Avatar
Finally got my car hooke up to a computer after eliminating any ignition faults,
computer says my air flow meter has gone bad, i was recomended to change to a z32 300zx AFM with SAFC II, which will last up to 500 BHP...
Do any of you have any other recomendations?
is there anything special about the swap or are the sensors basicly the same?
any help would be greatlly appricated...
10x in advance, alon...
The only computer i have in my car is a boost conroller...1996SilviaS14
Old Dec 21st, 2006, 03:07 PM   #14 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
THAY CAN HANDLE MORE VOLTAGE. IM GETTING THE FORD LIGHTNING MAF
Old Dec 21st, 2006, 03:22 PM   #15 (permalink)
Alonzo
Alonzo's Avatar
do i have to get the safc? the ecu cant read from the z32 MAF?
how do i set the safc up? is it difficult?
is the ford maf better than the 300zx?
engine flush vs Bilstein Engine Flush vs not at all ak47m203 Off Topic 7 Feb 21st, 2008 03:06 PM
QR25DE zellx2004 Frontier 2 Jan 21st, 2008 08:21 PM
Cleaning the Engine Bay – For a Newbie by a Newbie aperumal Car Care 0 Sep 24th, 2006 10:26 AM
Engine power issues Stanza92MP Stanza 7 Jan 18th, 2006 02:17 AM
Seems like engine looses power Nismo20SER B14 95-99 chassis 21 May 10th, 2003 10:10 PM
