put a chain around through the intake manifold and put two bolts connected to the head. those top holes. be carefull not to mess up the injectors. and hook up a chain to the bolts
__________________ Quote of the Day From Our Shop "Quick, ill wiggle it while you tug on it"
cool, your saying to put bolts in the head on the exaust manifold side right? And then feed the chain through the IM then around the bolts on the exaust side right? or use two seperate chains: one around the IM and the other around the bolts?
GA16de with Ported Head, Intake Manifold, and TB, and bolt-on's.
240sx-SR-306hp. 292 tq.
one chain for each side , on the exhaust manifold side you would bolt one end of the chain with the bolt to the rear of the head. and the other to the front of the head. and then link the center to the hoist. and the intake man goes though that valley under it.
