Go Back   NissanForums.com :: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > SR20DE/DET Engines
SR20DE/DET Engines 1991-2002 Silvia
Old Oct 1st, 2006, 10:48 PM   #1 (permalink)
RPM22
sr20det engine in san Diego¿?¿?¿?¿
i really want to build a 240 with a sr20 in it but i plan on moving to san diego and i heard that the laws are crazy about that down there does anyone know anything about that or anyway i could make the swap legal¿
RPM22 is offline   Reply With Quote
Old Oct 6th, 2006, 06:20 PM   #2 (permalink)
rogoman
Super Moderator
rogoman's Avatar
Here's the bottom line:
The SR20DET is NOT emissions legal in the U.S. The SR can be cleaned up by using a CAT and keeping most of the OEM emission devices intact such as the EGR valve.
If the emissions testing in your state doesn't require a visual inspection of the engine compartment and your 240SX is an S13 which doesn't use OBD-II, then the car should pass. If the car is an S14 with OBD-II and the emissions testing equipment plugs into the OBD-II connector, then the car will fail; also if the facility does visual checking of the engine compartment, the car will fail.
In California, they do full emissions testing along with VISUAL checking.
R32 RB25 Engine or S14 SR20DET witch is better skyline_fan_gtr90 S13 240SX 1989-1994 6 Aug 7th, 2006 12:46 PM
SR20DET engine swap, suggestions Krizz_240sx S13 240SX 1989-1994 1 Nov 23rd, 2005 07:23 AM
Get SR20DET engine to pass in CA? In San Diego? 180sxBlkImpact General 240SX/Silvia/S12 200SX 0 Sep 20th, 2004 12:13 PM
Engine swap to SR20DET?????? |2ED-LINE B15 2000-2006 2 Mar 4th, 2003 08:37 AM
SR20det engine swap Kitryj SR-Series Engines (DE/VE) 1 May 8th, 2002 03:47 AM
