Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > SR-Series Engines (DE/VE)
SR-Series Engines (DE/VE) Engine Discussion: G20, 91-94 Sentra SE-R, NX2K, 95-98 200SX SE-R, 98-01 Sentra SE
Old Feb 26th, 2004, 11:16 AM   #1 (permalink)
nnoriega
Unhappy Oil Light delays going off at engine start
Hello friends, I have a little doubt, whe I start my car, specially al morning, oil light takes like 1 or 1 and a half second to go off, it`s that normal, i`m running castrol 20w50 with a fram oil filter, this oil filter doesn`t have the special vavlve that keeps the oil pressure in the engine, please let me know if it is for the oil and filter i`m ussing or if there`s something I should take care of right now before something happens to my engine, Old US SR20DE died on my cuz of an oil pressure lost, cuz the oil pump houssing got durty with some silicon, so I`m a little scared about another engine to die on me
http://members.cardomain.com/nnoriega
1993 Se-R , JDM SR20DE engine (soon det), new spark plugs, new rims, and lot`s of stuff comming.
If you accelerate too much, You Brake time, and if you slow down, I`ll beat you. Any way, catch me if you can :thumbup:
nnoriega is offline   Reply With Quote
Old Feb 26th, 2004, 11:42 AM   #2 (permalink)
lshadoff
Post Freak
lshadoff's Avatar
Fram filters are really low quality. The drainback valve doesn't work well so the filter empties rather quickly after the engine is shut off. Then when you start up, it must fill before there is oil pressure. Go with a quality filter like Mobil1 or WIX.
Lew
lshadoff is offline   Reply With Quote
Old Feb 26th, 2004, 04:34 PM   #3 (permalink)
nnoriega
How bout Bosh, I`ve heard that they are good, but I`ll look at your advice, thanks bro
Old Feb 27th, 2004, 04:37 AM   #4 (permalink)
BennittoMallito
Nissan Fanatic
BennittoMallito's Avatar
Ok the Fram isn't the greatest, but it works ok. OEM Nissan filters. I've only used others out of desperation.
But seriously. 20w50?!?! Are you for real? I used that grade on my 1976 Mini 1275e. That stuff doesn't belong in an SR20, even if it is castrol who make decent stuff. SR's have really narrow oil passages, especially the tubes that feed the cams. Go at least down to 10w30, you can even do 5w30. Better to leak a bit if that's the case.
92 SE-R, H/E/A/P/S^ :)
Wer bremst, verliert. :loser:
BennittoMallito is offline   Reply With Quote
Old Mar 3rd, 2004, 03:32 PM   #5 (permalink)
nnoriega
Thanks bro, i`ll do that, when I put that oil into my sr20 was because of my low budget, in that time, a install the jdm sr20de and put that oil, but never again, promisse
Old Mar 4th, 2004, 10:40 AM   #6 (permalink)
BennittoMallito
Nissan Fanatic
Word. Best to change it more often the next few times too. Your SR will thank you. Cheers ~B
Lab Tested Used Motor Oil 1.8L Bror Jace QG18 1.8L Engine 12 Jul 23rd, 2004 09:42 PM
First start after an oil change is SCARY! BillDawg GA16DE 1.6L Engine 15 Mar 29th, 2004 04:09 AM
My first engine oil leak 96R50 Truck & SUV 17 Dec 31st, 2003 06:12 AM
Instructions and the step by step of swap BobbyRay S13 240SX 1989-1994 47 Dec 22nd, 2003 10:09 AM
check engine light & emissions nismofreak GA16DE 1.6L Engine 5 Jan 21st, 2003 11:15 PM
