hey there folks. i have problem with my sentra. there is a squeking, rattling noise that is coming from the top left corner (when u are in front of the car) of the engine. it makes the noise when it is at idle speed or when i come to a stop and it stops when i start to move or when i rev the engine. if any one knows of this problem please help. if this helps i was working on my car today and i noticed that my o2 sensor was not connected propely. also my car is a 99 sentra se-l and it has 28,000 miles. thanks
well the only problem about the warranty is that the car has a salvage title and i bought from a mom & pop dealer. and when i reconnected the sensor it did not fix the problem.
Originally posted by mayco well the only problem about the warranty is that the car has a salvage title and i bought from a mom & pop dealer. and when i reconnected the sensor it did not fix the problem.
Squelling noise, tighten your accessory belts a bit. One tensioner can be found on the P/S mount facing the firewall and obscured by P/S lines.
The other is on the Alternator bracket itself.
If it is your CHAIN tensioner, that is located under the oil filter and is a pain to remove. I believe you can find out how to check it here on the post. If not buy a HAYNES manuel, that is how I found mine and believe there is a check section in there somewhere. Good luck.
see my ride at click the link
sign my guestbook!
thanks for all the info. some mech told that it might be my water pump. cause i sprayed some wd40 in the small hole that it has and it stoped for a while so ill try replacing the pump first . tell what u guys think.
