Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > SR-Series Engines (DE/VE)
SR-Series Engines (DE/VE) Engine Discussion: G20, 91-94 Sentra SE-R, NX2K, 95-98 200SX SE-R, 98-01 Sentra SE
Old May 9th, 2006, 03:14 PM   #1 (permalink)
kaotekXe
engine temp problem
so ive driven my car like this since i did the sr20de swap from my ga16. so pretty much the car reads that its overheating but its not. ive swaped both temp sensors but it still reads the same. but the car isnt overheating. ive hooked up autometer gauge to it and its fine. what could the problem be. could i be using the wrong sensors?
kaotekXe is offline   Reply With Quote
Old May 9th, 2006, 03:39 PM   #2 (permalink)
racerdude7730
im not sure but i just did a bluebird swap from the sr20de and it does the same with me i think its just all the motors are different or something
racerdude7730 is offline   Reply With Quote
Old May 9th, 2006, 04:47 PM   #3 (permalink)
Navi00
Send a message via AIM to Navi00 Send a message via MSN to Navi00 Send a message via Yahoo to Navi00
You're saying the tempature gadge is saying it's over heated? like on the dash?
||Fifth gear ephoria||
==||ProjectR||==
Navi00 is offline   Reply With Quote
Old May 9th, 2006, 04:58 PM   #4 (permalink)
kaotekXe
yea the dash gauge says its overheated. but i dont even start the car just turn the ignition on and the needle starts climbing.
Old May 10th, 2006, 02:40 PM   #5 (permalink)
racerdude7730
mines not that bad but once the cars on it will spike the heat gauge on the dash that it will not go any higher but the motors fine i just think they all dont get alone with each other so i wouldnt worry about it unless it really bothers u lol
Old May 10th, 2006, 04:11 PM   #6 (permalink)
HATEnFATE
Because Size Matters
HATEnFATE's Avatar
Send a message via AIM to HATEnFATE
If the sensor and the ecu are from different locals (i.e....jdm, udsm, etc.....) then they are probably reading different voltages, ohms, amps, whatever. They'll read weird on the guage because the ecu is getting a different current even thought the engine is fine.
If you are trying to get faster on a track you will go off course. The question is where, and how bad..............
JAY
www.ilovetoargue.com
HATEnFATE is offline   Reply With Quote
Old Aug 14th, 2008, 05:23 AM   #7 (permalink)
Ham
Ham's Avatar
Have the same issue with my car. Replaced the sensor & fan switches but to no avail. My gauge on the dash stays down flat. It seems to be an issue with these engines.
If the car is overheating you will notice your rev's will go up higher when idling (After engine has warmed up) you may smell the coolant and you tend to loose power!
Ham
Ham is offline   Reply With Quote
Let's resolve it! Will the VTC "clicking" problem DAMAGE my engine? hoyshnin J30 1989-1994 Chassis 2 Sep 18th, 2005 12:23 PM
Murano engine rev problem NauTiCa General Discussion 0 Aug 27th, 2005 01:38 PM
engine problem (Sentra XE 2001) maxtin QG18 1.8L Engine 5 Jun 10th, 2005 03:39 PM
96 Quest with P0325 - engine knock problem jdevera Truck & SUV 4 Dec 20th, 2004 08:09 AM
SR20DE - internal engine problem after head decking signat New Member Forum 1 Aug 4th, 2003 11:58 AM
