Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > SR-Series Engines (DE/VE)
SR-Series Engines (DE/VE) Engine Discussion: G20, 91-94 Sentra SE-R, NX2K, 95-98 200SX SE-R, 98-01 Sentra SE
Old Apr 30th, 2006, 11:30 PM   #1 (permalink)
madvaz
Losing Oil (possible solution)
I have a 2002 Nissian ser Spec V and I noticed that I've been losing oil at a fast rate. I don't have an external oil leak (no leaks on the drive way). I usually have to pour 1 qt a week and it's killing my wallet as I use syntectic oil.
What could be the problem? My car has been misfiring in cyclinder 3 and I've replaced the coil and still caused the misfiring? It does smell like burned oil..so the oil is getting burned but where?
Should I take in to the dealer to get it check out?
Thanks
madvaz is offline   Reply With Quote
Old May 1st, 2006, 02:23 AM   #2 (permalink)
chris859
Just another nissan fan!
Send a message via Yahoo to chris859
First of all...not sure what to tell you on the oil loss, secondly, you might be better off posting in the right section... You have a qr25, not an sr20 like this section is meant for.
chris859 is offline   Reply With Quote
Old May 1st, 2006, 02:54 AM   #3 (permalink)
Char
Nissan Fanatic
Send a message via AIM to Char
probably blew a piston ring or something. How does it drive? It sounds VERY serious.
My Purple People Eater
BWAHAHA! I Finally disabled that stupid Door Ajar Ding! *Eye Twitches*
Char is offline   Reply With Quote
Old May 3rd, 2006, 12:04 PM   #4 (permalink)
nova73guy
Nissan Addict
nova73guy's Avatar
Send a message via AIM to nova73guy Send a message via Yahoo to nova73guy
bad piston rings. If it's still under warranty, I'd take it to the dealer. Also, you don't have to use synthetic in these cars. Synthetic oil only benefits very high horsepower cars.
Get plastic surgery, there ain't no maybe. Your ugly face still ends up on your baby.
nova73guy is offline   Reply With Quote
Old May 5th, 2006, 08:46 AM   #5 (permalink)
HATEnFATE
Because Size Matters
HATEnFATE's Avatar
Send a message via AIM to HATEnFATE
Dealer might be the best place. It's an 02 and if it's stock you might still have some ground to stand on. How many miles do you have on the vehicle?
If you are trying to get faster on a track you will go off course. The question is where, and how bad..............
JAY
www.ilovetoargue.com
HATEnFATE is offline   Reply With Quote
Old May 5th, 2006, 09:20 AM   #6 (permalink)
Pamay
Pamay's Avatar
Send a message via ICQ to Pamay
Cool
Dude take for a compression test, pep boys and if #3 cylinder is low, go to the dealers to get a claim. has it ever overheated as it could be a blown head gasket. remove rad cap and see if it looks like oil is in there then you would know you got a blown gasket.
hey guy you dont have to have big power to use synthetic oils that total crap talk
Pamay is offline   Reply With Quote
Old May 5th, 2006, 11:20 PM   #7 (permalink)
chris859
I agree...synthetic benefits ALL cars. It is great for its superior anti-wear, and anti-friction properties alone.
Old May 6th, 2006, 11:47 AM   #8 (permalink)
madvaz
losing oil update
thanks guys for the tips...I took it to the dealer, and they did a compression test on my car.
The reason why i'm losing oil at a fast rate is because the Catalytic converter is clogged.
I had to leave my car at the dealer and they told me they would have to replace the whole engine! Luckly for me, warrenty is going to cover my new engine. They said I already did some internal damage to the engine. Part of it was the piston ring, cyclinder, ect..
As for Synthetic oil, the dealer said it did no harm to my car and was ok to continue using the same oil.
Old May 6th, 2006, 11:15 PM   #9 (permalink)
Char
Nissan Fanatic
how could a clogged cat blow a ring?
MOTOR OIL VS. GEAR OIL Cgamboa B14 95-99 chassis 18 May 6th, 2006 10:44 PM
Changing Oil types ace B13 91-94 chassis 18 May 6th, 2006 10:10 PM
Oil Change Destroys Engine !!! 1996 Nissan Altima andym U13 1993-1997 Altima 12 Jun 23rd, 2005 07:05 AM
Limited time showing, come one come all!! Marvin Off Topic 43 Jan 14th, 2005 07:35 PM
change your own oil sethwas B14 95-99 chassis 82 Dec 28th, 2003 06:12 PM
