Go Back   NissanForums.com :: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > SR-Series Engines (DE/VE)
SR-Series Engines (DE/VE) Engine Discussion: G20, 91-94 Sentra SE-R, NX2K, 95-98 200SX SE-R, 98-01 Sentra SE
Old Feb 20th, 2006, 10:22 AM   #1 (permalink)
200sx98fl
U13 BB Owner
200sx98fl's Avatar
Question U13 swap problems....help pls
ALright with help from another member form here i have managed to get the u13 bolted in to my b14 200sx SE 5spd chassis. It was a bitch with the prothanes sticking out of the mounts and yes i do have all the sr20 motor mounts and brackets besides the crossmember the ga16 5pd is the same. It actually looks like i could of used the rear 1.6 mount but neways here are my problems.
First off i cant get the top bolt in the dogbone mount(the top hole), i have a klien's flathead in there now, It seems the jpipe(U13) hangs on the dogbone kinda of prevents the mount from going up any further.
Second off, i bought the nx9 hdss kit and have it installed correctly and lubed the throwout bearing and tested it before i put it on and once it was on with the tranny aarm. It had maybe a half ince of play. Now i have a ga16(was good before motor blew) and sr20 clutch cable (good too) I know both of them are in good shape but its seems its still long. The clutch pedal sticks to the floor. Now i have a b13 sr20 tranny in there but could it have the wrong tranny arm on there that holds the black rubber piece. Also i read about a adapter someone made at homedepot...any one have some pics to elaborate on this???
Third, the stock front mount intercooler looks like its not gonna work. I think i have to go under the radiator instead of the sides because theres nothing but metal unless i start cutting??? Maybe i can just get some hoses and make it work untill i can buy a piping kit.
Also i am going to take pics when i get home from work to help. Thanks for any help...
there are some pics in my link below of the motor and stuff on it b ut i will have more tonight.
My Ride Undergoing U13 swap.
96 Nissan 200sx Auto
95 Eclipse GS M/TCAI & 2.5 Cat Back Exhaust.
200sx98fl is offline   Reply With Quote
Old Mar 14th, 2006, 12:36 AM   #2 (permalink)
PDX_SER
what i did with the front mount was flip the bracket upside down and then the front motor mount will work, but it takes a pry bar to get it in there since the bracket is a little to the drivers side when flipped over and sits higher. and what i did with making a temp turbo piping setup is i got two flex coolant hoses and went straight from the turbo to the intake, it works fine if you need to run it for a little while and make sure everything works.
PDX_SER is offline   Reply With Quote
240SX Driveshaft SR20 Swap rocksteady_racer SR20DE/DET Engines 1 Aug 27th, 2005 08:26 AM
Ordered Bluebird swap Questions allmotork20 SR-Series Engines (DE/VE) 1 Jul 23rd, 2005 07:13 AM
sr20dett swap.....wiring problems innes177 New Member Forum 2 Feb 23rd, 2004 08:51 AM
ka24de swap problems [Virus]Sil-eighty General 240SX/Silvia/S12 200SX 1 Feb 3rd, 2004 07:02 AM
Common Problems with Det swap into se-r sr21lbmonster SR-Series Engines (DE/VE) 0 Jun 20th, 2002 10:22 AM
