You'd better get some wicked cleaner on that. Your going to have major rust issues. The battery will be fine. The battery's plastic case is designed to resist battery acid corrosion, your car isn't. I'd take everything out and clean the crap out of the metal. Scrub it with something that is a strong base.(acids & bases) Once your done you'll most likley have to repain the section or you'll start to have severe rust issues if your in a snow belt.
Check everywhere that the acid could have gone. inside your frame rails and all. The most damage will be in a place you can't see.
If you are trying to get faster on a track you will go off course. The question is where, and how bad..............
JAY
www.ilovetoargue.com
