First you need to determine if there's a fuel or ignition problem.
When the motor fails to start, see if you're getting spark at any plug; use a spare plug, laying on top of the valve cover, connected to an ignition wire.
An easy way to test the fuel pump and filter is to disconnect the fuel hose from the top of the fuel filter and insert a long length of spare hose into the top of the fuel filter with the other end draped over the fender going into a catch can placed on the ground. Now turn the ignition key to the run position but DO NOT START THE ENGINE. You should see fuel going into the can at a good rate for several seconds.
KA > SR anyday of the week.
