Yes after I discoverd no power to pin 29 and 30 on the controller, I performed test on the AT controller it self and it tested fine. I knew it was a power problem. After dreaming about this for several days a light went off in my head. I work in the IT field and I have a line tracer (hook one end of wire to device it sends signal down wire and you can trace to other end). I did this last night and shazzam it took me to the bottom right fuse holder next to the drivers compartment. The clip the fuse sides in was damaged and pushed back. After repairing this I slid in the fuse hooked the battery back up and everything was working fine. Note to anyone tracing this again the fuse is marked reverse tail lamp, and it also powers the AT controller.
Also note anyone have problems with shifting. I changed this trans because it would not shift from second to third or overdrive. Then I started trouble shooting other possible problems and thats when I discovered the power problem going to the AT controller.
The Nissan Mannual is the best tool for diagnostics and trouble shooting problems. Best tool I have bought yet.
Thanks everyone
Bud
Originally Posted by Mekanik22
From the ignition switch, look for a green wire with a blue stripe on it. That is your wire. It splits right before the A/T controller to go to terminals 29 and 30. Let me know how you did with that...
Secondly, are you trying to test the A/T controller itself? Because you could just measure the resistance right at the controller itself to find out if it's any good. It's on the right side of car mounted on the right side of the firewall right above the ECU.
