Originally Posted by EP240SX
For some reason after I put the silencer on my exhaust my car no longer idles very well. When I deccelerate the rpms drop too low and my car almost dies. When im just at a stand still the rpm's dont level out, they move anywhere between 300-800 just going up and down.
Is this the timing? What can I do to fix this?
When it finally levels out......EVENTUALLY it idles at 800rpms. So I dont think adjusting the idle is the problem
Why don't you remove the silencer as a test to see if the problem goes away; if the problem goes away, then the silencer may be introducing a sizable amount of back pressure.
If the problem doesn't go away, then the silencer is not related to the problem; the problem could be due to the following:
1 - Dirty fuel injectors.
2 - Dirty air filter.
3 - TPS harness connector.
4 - Dirty IAA valve.
