Old Apr 29th, 2005, 12:57 AM   #1 (permalink)
faethen
Unhappy problem with ac(please help)
I have a 1990 240sx, I have a problem with my air conditioner. The blower works, but it does not blow cold air at all and when i press the AC button, the green light does not come on either. Can anyone please tell me what the problem might be? and how to fix it? any tips or suggestions will help...
faethen is offline   Reply With Quote
Old Apr 29th, 2005, 07:23 PM   #2 (permalink)
2lowpaco
Send a message via AIM to 2lowpaco
If im not mistaken the light will not come on if the compressor isn't coming on. Check the connections to the compressor, and also in the relays that are under the hood, there is an ac relay. If everything looks ok then your probably just low on freon. If its low enough on freon the compressor wont come on. Hope this helps.
You're not low, until you're paclow. :thumbup:
2lowpaco is offline   Reply With Quote
Old Apr 30th, 2005, 09:17 AM   #3 (permalink)
sunnydet90
LUCKY SLIDES 2 2/25/06
sunnydet90's Avatar
Send a message via AIM to sunnydet90 Send a message via Yahoo to sunnydet90
are you sure the compressor hasnt blown up yet? older nissans are notorious for a/c goin out my sentra and 240 had a/c go out.
2lowpaco i didnt know you were from nashville where bouts do you live?\
Don
car cost=$500 total parts cost so far=$4750+
sunnydet90 is offline   Reply With Quote
Old Apr 30th, 2005, 09:43 AM   #4 (permalink)
2lowpaco
If you know someone with an ac recovery system they can pump enough in to test and then suck it back out. Im sure there is another way to test the pump but I have a recovery system so thats the only way I know how. And I live in Donelson but Im usually in Lebanon.
Old Apr 30th, 2005, 02:03 PM   #5 (permalink)
sunnydet90
sunnydet90's Avatar
awesome i used to live in mt. juliet but i moved to murfreesboro. i went to school at wilson central in lebanon.
Don
Old May 2nd, 2005, 01:38 AM   #6 (permalink)
BrianNVdCustoms
BrianNVdCustoms's Avatar
Send a message via AIM to BrianNVdCustoms
Don
compressor isn't coming on. probably no freon in the system. have an A/C system test to check pressure. unless you know some one with an Automotive 609 lisence to buy freon, you'll need a shop to charge the A/C anyway. other possibility is the high/low pressure switch located on the accumlator/drier. The drier is located just below the battery and toward the driver in the engine compartment. check a manual and test out the switch if you're curious. probably no big deal man, just have the system charged. best of luck.
Brian aka "Woody"
**2000 Audi S4 ** (For sale)
**S13 240SX **
Listing mods is advertisement for theft :rolleyes:
BrianNVdCustoms is offline   Reply With Quote
92 240SX: Intermittent Shift Problem 240rocker S13 240SX 1989-1994 7 Jun 8th, 2005 09:59 PM
NX2000 Cold Start Problem Seeking Help lucifer SR-Series Engines (DE/VE) 4 Mar 4th, 2005 08:18 AM
Problem: Rear Brake Noise wayne2k1 Suspension & Brakes 13 Aug 1st, 2003 12:57 AM
Hi all, I'm new here. Got a problem with my B14, pls help. Mayonaise B14 95-99 chassis 8 May 12th, 2003 06:03 AM
CA18DET Motor Swap Problem Zushi S13 240SX 1989-1994 3 May 7th, 2003 04:15 PM
