Old Mar 3rd, 2005, 08:06 PM   #1 (permalink)
flagg79
89 240SX seatbelt problem
All of a sudden, the driver side seatbelt is locked. I can disconnect it from the automatic part, it will retract fully but then I cannot pull it back it as it is locked. However, if I pull a bit, give it slack, then pull a bit more I can eventually get enough slack to cover my body--but then I cant move because the belt is still locked as if I am slamming on the brake!!! Any suggestions before I drop it off at the dealer? Thank you.
flagg79 is offline   Reply With Quote
Old Mar 4th, 2005, 10:47 AM   #2 (permalink)
DaCheat
Tarmac Terrorist
DaCheat's Avatar
Send a message via MSN to DaCheat Send a message via Yahoo to DaCheat
DELETED!
Get Rid of the electric seatbelts, they work well when new, but just like anything mechanical when they are old they cause problems, get some harnesses or find some donor unit's from a Canadian car!
The Canadian models didn't have the electronic seatbelts
DaCheat
DaCheat is offline   Reply With Quote
Old Mar 4th, 2005, 03:35 PM   #3 (permalink)
kaptainkrollio
Banned
kaptainkrollio's Avatar
There should be lifetime warranty on the seatbelts. Call the local dealer and see what they can do.
kaptainkrollio is offline   Reply With Quote
Intermittent (no) starting problem Actionclaw S13 240SX 1989-1994 14 Feb 9th, 2006 08:33 AM
Ecu harness for 89 m.t. 240sx tubular31 S13 240SX 1989-1994 2 Feb 13th, 2005 11:17 PM
Nissan 89 Pickup Engine Cutout Problem spectrasort Truck & SUV 3 Oct 1st, 2004 07:11 PM
97 Transmission for 89 240SX? Tony240sx S13 240SX 1989-1994 1 May 18th, 2004 12:04 PM
Need advice: '89 or '91 240SX? nismoweapon S13 240SX 1989-1994 31 Aug 15th, 2003 09:38 PM
