Old Feb 28th, 2005, 02:20 AM   #1 (permalink)
240droptop
Send a message via MSN to 240droptop
headlight problem
ok so heres the thing one nigth when I pulled up to my house I noticed my left headlight was out I figured it was burnt out and decided meh w/e time for som,e new headligths so I orderd some diamomnd cut HD's. k good a week or two i will have two ehadlights again. couple nigths alter I noticed that once again i had two ehadlights the left one was on again..... since then some nights I will have both headlights other nights only the right one. I figure it must be elctrical but what should I check any ideas thanks
Tyler
240droptop is offline   Reply With Quote
Old Feb 28th, 2005, 02:31 AM   #2 (permalink)
Dustin
Locked and Loaded
Dustin's Avatar
Send a message via AIM to Dustin Send a message via Yahoo to Dustin
try pulling GENTLY on the wires, and if one pulls out, then theres your problem, but it sounds like a loose wire.
95 Volkswagen Golf Sport - Low, slow, and loud purchased 4/5/08
93 Nissan Sentra SE 2 door - sold 4/5/08
88 Honda Civic DX Hatchback - sold 9/26/07
85 BMW 325e Coupe w/ 88 I motor swap - sold 2/24/07
93 Sentra XE 4 door - wrecked 7/29/06 totalled.
90 240SX Fastback - sold 7/15/05
Dustin is offline   Reply With Quote
Old Feb 28th, 2005, 12:38 PM   #3 (permalink)
240droptop
hopefully thats all it is I'll go try it right now
Tyler
Old Feb 28th, 2005, 05:31 PM   #4 (permalink)
240droptop
Exclamation
k well i checked the plug that goes into the back of the headlight that was in fine, is that the wire you were talknig abot if not where is the other ones I should check thanks
Tyler
Old Feb 28th, 2005, 05:52 PM   #5 (permalink)
Dustin
Locked and Loaded
Dustin's Avatar
look for any wires running to the plug you mentioned, and if you have to, bust out a multimeter, and measure the amps..
Old Mar 1st, 2005, 01:43 PM   #6 (permalink)
DaCheat
Tarmac Terrorist
DaCheat's Avatar
Send a message via MSN to DaCheat Send a message via Yahoo to DaCheat
When the headlight is burnt out, hit it with enough force to see if it comes on, headlights on my old Aerostar did that once in a while.
It is usually cause by corroded connections between the bulb and the headlight connection. This usually means time to replace the headlights, try some vasaline on the connections as well that will never hurt.
DaCheat
DaCheat is offline   Reply With Quote
2001 SE Headlight Problem Rajendra A33 2000-2003 Chassis 1 Feb 7th, 2008 12:12 PM
Low beam headlight problem solarscar Truck & SUV 2 Oct 7th, 2004 03:27 PM
Crystal Headlight Problem... RacinConcept Cosmetic Mods 10 Feb 17th, 2004 06:41 PM
Weird Headlight Problem 93sr20det S13 240SX 1989-1994 8 Jan 23rd, 2004 02:21 AM
Problem with tranny... J30tour General Discussion 0 Apr 19th, 2003 10:50 AM
