Old Oct 23rd, 2002, 12:19 PM   #1 (permalink)
rahdog76
Posts: n/a
Question Noobie questions trani and engine
Sup peoples im new to the 240sx world I have a 1989 240sz with 80k milles . I just wanted some advice my trani slips when im drivin at about 3000 rpm it doesnt happen all the time but it usually happens when im on the freeway running at the same speed for a while. Any info on that i just dont want to go in blind when i go to the shop. Another question what engine does it have i know its a 2.4 4 cylinder but what engine model. What do u guys think are the first mods i should do to make it alittle more fun to drive. THanx fellas appreciate the help.
Old Oct 24th, 2002, 08:10 PM   #2 (permalink)
KaOz
KaOz's Avatar
Send a message via ICQ to KaOz Send a message via MSN to KaOz
Cool Dear friend...
Hey dOOd,
Well, from what it sounds like... you are slipping in a steady 2nd gear? 1st gear you probably don't notice much.. cuz it is a quick rev (short gear). However, in 2nd gear you probably feel it cuz it is the *driving idle* if you get what I am saying. Could be that your tranny is giving up bro. I would suggest you take it to the shop A.S.A.P. before anything else -worse- happens! You don't want wear being induced onto your engine (even though the TRUCK ENGINE can handle it)! heh!
Your engine code is known as: KA24DE (KA - Series/24 - Displacement/DE - Direct Electronic Fuel Injection *If I am not mistaken*). Either way, it is a 2.4 litre 4 cylinder Nissan Truck Engine. From 1989-1990 the engine produced 144HP while the 1991-1993 KA24DE produced 155HP with matching torque range. It was taken from the Nissan truck platform because of its fuel economy, mid range power, and availability (cheap engine to produce too). That is why they call it a TRUCK ENGINE. It is seriously indestructable man. You can try to nuke it and you'll hurt the bomb rather then the block. Hahah!
In terms of performance upgrades... your pretty much left in the dust my friend. There aren't too many (if any) upgrades that you can do to the engine. The simple air intake, ecu re-program, etc... would give you some little punch... but don't expect anything more then 180 HP if your lucky. The reason for this is because the "power potential" with that engine is very difficult if not impossible to grasp. Like I mentioned in a previous post, there have been only a handful whom have achieved the ideal 250-300HP but nothing more - and after a hefty BILL to pay!
I suggest you do a CA18DET and/or SR20DET engine swap for your car. The SR20DET will bring you to a good 200HP (S13 one) and that is more then enough to toy around with and give a little kick in the ass to those Civics on the roads.. (eeeew... Front Whell Drive... NEVER AGAIN!)
There are tons of sites and performance shops out there... check em out... and ask questions - it doesn't hurt!
I suggest you check out www.sr20detperformance.com for any engine questions/parts that you may need!
Take care,
KaOz.
"Straight roads are for fast CARS, Corners are for fast DRIVERS"! :dumbass:
Co-Owner of SEQUENCE Garage (Toronto, Canada)
www.sequence-garage.com
We specialize in SR's and soon to be the R32/RB! :fluffy:
KaOz is offline   Reply With Quote
Old Nov 5th, 2002, 07:55 PM   #3 (permalink)
boro240
Posts: n/a
his engine is a KA24E, since it is SOHC and not DOHC like the DE. D=dual overhead cams E=electronic fuel injection.
