CA18DET problems need help ASAP - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > S13 240SX 1989-1994
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Nov 16th, 2004, 01:21 PM   #1 (permalink)
Send a message via AIM to silfortytypex
Unhappy CA18DET dellima, need advice...
Hello, I recently purchased an 89 200sx which has the CA18DET motor and I am having a problem with my car, but I am unsure as to what it is, and I hope to find some suggestions. Here are the symptoms that I am getting...
The car usually wont start, but it'll crank all day, and when it does start it sputters ALOT and wont hold an idle unless I ligtly tap/hold on the gas pedal. And when I did maraciously get it started those very few times, it died after a few minutes or so and seemed to use ALOT of gas, and has almost feels very sluggish, like its either not getting enough air or not getting enough gas. I have checked the compression on the engine and that is fine, I have also checked the ignition coil packs and spark plugs, those are fine. I have cleaned out the little sensor int he MAF so I am sure that that is fine. The oil is rather new and normal consistancy. I am wondering if the fuel pump could be the symptom? Could it be a bad sensor which is cuasing these types of problems? Just note that it wont start at all amymore... I would not trust any mechanic here since I don't trust many German mechanics, I'd rather do the work myself. What could the car's problem be?
silfortytypex is offline   Reply With Quote
Old Nov 17th, 2004, 02:42 AM   #2 (permalink)
RB Enthusiast
Nizmodore's Avatar
Send a message via ICQ to Nizmodore
AFM (MAF) or a major air leak between the AFM and the turbos inlet.....Has to be.....
Holden VL Commodore Calais......a domestic Aussie car thats RB Nissan powered (From the factory) and hated by Australian domestic people and Japanese import people alike, due to its mixed heritage.....*sigh* I can't win can I?
Nizmodore is offline   Reply With Quote
Old Nov 19th, 2004, 12:14 PM   #3 (permalink)
Cool
Okay thanks, I just ordered a Z32 MAF, when I get it and wire it up I really hope this fixes the problem.
Any more suggestions would be greatly appreciated!
Old Nov 19th, 2004, 04:00 PM   #4 (permalink)
Send a message via AIM to dj42000_2000
I had a problem with bad hesitation and it was due to a bad fuel pump. check your pressure and check your engine vacuum.
dj42000_2000 is offline   Reply With Quote
Old Nov 24th, 2004, 04:50 AM   #5 (permalink)
hey man, The easiest thing to do is to pull the ecu and do a self diagnostic check, mode 3. That will let you know if there are any sensors out, instead of just trying to guess. Plus, you do know that in order to run the z32 mafs, you will need a piggy back computer (such as a s-afc) or a stand-alone system, otherwise your car won't work at all. Anyway, if you have any other questions feel free to email me at Tweaktac@aol.com I myself have a ca18det in my 240sx, so i may be some help...good luck man
Tweaktac is offline   Reply With Quote
Old Mar 12th, 2005, 06:09 AM   #6 (permalink)
aldyno - S13's Avatar
Send a message via ICQ to aldyno - S13 Send a message via MSN to aldyno - S13 Send a message via Yahoo to aldyno - S13
the ca18det manual
Hi, I went into a ca18det project last year and OPIUM (from this forum) gave me the manual, it helped me like he could NEVER imagine.
It teaches you how to perform every ECU mode and how to manually check every part of the engine so you know if they´re really in good working order.
For easier download of the manual (30mb +/-), search my posts, there´s one named "ca18det swap", it´s in there!
Goog luck!
:cool: If speed kills, I'm gonna die soon. :cool:
aldyno - S13 is offline   Reply With Quote
BB code is On
Problem/No Problems Zac QR25 2.5L Engine 69 Aug 25th, 2005 07:41 PM
ca18det clutch problems 87b16crx S13 240SX 1989-1994 4 Aug 2nd, 2004 02:10 PM
ca18det problems CA18FASTBACK92 S13 240SX 1989-1994 7 Jul 2nd, 2004 05:03 PM
My Nissan 350Z Lemon w/Many Problems! C1 Bender Z33 350Z 2003+ 8 Aug 10th, 2003 03:43 PM
CA18DET swap problems? Oversight E/CA-Series & GA16i Engines 1 Jul 13th, 2003 04:00 PM
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
