Old Oct 27th, 2004, 09:45 PM   #1 (permalink)
little240boy
Nissan Fanatic
Hot Valve cover
I've been noticing lately that when I pop the hood, my valve cover is really hot, even smells hot too. My temp. gauge is always right in the middle and I don't have any shortage of coolant or any leaks! I just changed my oil too. The next day i changed it, my cover was so easy to touch i could put my hand on it forever. today i tried and nearly burnt the shit out of my hand! Anyone know what could possibly be going on? Is it because I have the heater on all the way home from work?
little240boy is offline   Reply With Quote
Old Oct 28th, 2004, 06:35 AM   #2 (permalink)
TwoForty
maybe your timing is off that makes your engine run hotter
TwoForty is offline   Reply With Quote
Old Oct 28th, 2004, 08:13 PM   #3 (permalink)
Kelso
so close to turbo...
Send a message via AIM to Kelso
im sure thats normal. if all your fruids are up like they should be, i dont see why it would run hotter. your not supposed to touch an engine after youve jsut driven for a while
they get hot as hell. it will burn the shit out of you no doubt.
turning on the heater actually draws heat from the motor. it would , if anything, make the motor run cooler.
Rules:
1)Search – search, search, search. The search button is in the header of EVERY page loaded on NissanForums.com. Search is the third link in from the right on the header. Please use it before you post. Even though this forum is relatively new there is a lot of good information in the database of previous posts. You might find that your question has already been discussed at length and answered.
Kelso is offline   Reply With Quote
Valve Cover change, bolt size problem xbrandonx GA16DE 1.6L Engine 25 Dec 31st, 2005 10:44 AM
Valve cover gasket + spark plug seal ppupet L30 1998-2001 Altima 1 Jul 2nd, 2004 06:59 PM
Valve cover problems! Derrick GA16DE 1.6L Engine 3 Jun 9th, 2004 04:27 PM
Valve Cover Gasket Replacement mr_wright1911 U13 1993-1997 Altima 1 Apr 13th, 2004 04:18 PM
Valve Cover Painting SR20D_GTI Cosmetic Mods 16 Feb 6th, 2003 12:27 PM
