Old Oct 24th, 2004, 06:51 PM   #1 (permalink)
Kelso
so close to turbo...
Send a message via AIM to Kelso
brake light
ok this is really weird. i never use my e brake because it can lock up the rear brakes if you park it like that all the time but for some reson the light keeps coming on. the ebrake isnt on at all. its not up, and i can tell my brakes arent sticking when i drive.
heres the actual scenario: usually it happens when the car is still cold. my ebrake light will come on soon after i leave my house and even when my tempereature gauge is sitting in the middle for quite some time the light stays on and just goes off when it wants. sometimes im just driving and it pops on. its only done this in the past week or so. anybody know whats going on?
Rules:
1)Search – search, search, search. The search button is in the header of EVERY page loaded on NissanForums.com. Search is the third link in from the right on the header. Please use it before you post. Even though this forum is relatively new there is a lot of good information in the database of previous posts. You might find that your question has already been discussed at length and answered.
Kelso is offline   Reply With Quote
Old Oct 24th, 2004, 10:08 PM   #2 (permalink)
kaptainkrollio
Banned
kaptainkrollio's Avatar
check your brake fluid. i had the same problem
kaptainkrollio is offline   Reply With Quote
Old Oct 25th, 2004, 06:39 PM   #3 (permalink)
Kelso
just checked it...its above the min and below the max...almost right in the middle... so im back to nothing...fuck
PS i havent been able to talk to my friend about the suspension for your friend...schedules are hard to get a call time for him cause of work and college
Rules:
Old Oct 25th, 2004, 07:32 PM   #4 (permalink)
kaptainkrollio
Banned
okay, whatever.
Old Oct 25th, 2004, 11:55 PM   #5 (permalink)
HybridAndy
Send a message via AIM to HybridAndy
Add some DOT3 fluid anyway and see if the light goes away. My 240's was doing the same thing. The light would come and then go off randomly. There was some fluid in the MC tank but I put some extra in and it went away. Hopefully you don't have the same problem as me because I'm continuing to loose fluid. My cars been parked for a few weeks now with a failed clutch (I've got a new SR20 getting ready to swap in) and I've noticed a puddle under the drivers side firewall (light is back on again too). I think I've got a crack in one of the hard lines but all 4 of my jackstands and jack are over at the shop under my clip so I can't even take a look at it.
HybridAndy - 240sx/SR20 owner
'90 240SX hatchback - 180sx front clip on it's way, project car
'98 Civic EX - CTR headlight and grill, Kosei K1's, daily driver
HybridAndy is offline   Reply With Quote
Old Oct 27th, 2004, 10:42 AM   #6 (permalink)
dj42000_2000
Send a message via AIM to dj42000_2000
check the e-brake sensor- my friends switch is just permanently reading closed. kinda annoying, but it could be worse.
dj42000_2000 is offline   Reply With Quote
Old Oct 27th, 2004, 06:23 PM   #7 (permalink)
Kelso
no if it was a sensor it wouldnt be randomly coming on and off, the good kaptain was right.
even though it was well above the minimum amount of fluid, i decided to pour some in anyways last night and today i had no light at all.thanks guys
Rules:
Old Oct 27th, 2004, 07:16 PM   #8 (permalink)
kaptainkrollio
Banned
that was hybridndy, not me.lol
Old Oct 27th, 2004, 08:02 PM   #9 (permalink)
HybridAndy
Ha ha, don't be too happy yet. It's never a good thing to be low on brake fluid. It's possible your pads are just worn enough that the fluid is being used to push the pistons in the calipers out further but I'm pretty sure with my car I've got a brake leak somewhere and it's one of the hardlines. Hopefully I'll get my jackstands and jack back from under my SR20 clip and I can see what my problem is and fix it.
Old Oct 27th, 2004, 08:28 PM   #10 (permalink)
Joel
Pivot 180
Joel's Avatar
you need to be at the max line - not below it. Half way isnt enough fluid.
SilviaWA
1992 180SX: cwest, vertex, wise, pivot, gemax, embleton, kyb, blitz, whiteline
Joel is offline   Reply With Quote
Battery Light, then Brake Light MannyNoela J30 1989-1994 Chassis 1 Aug 9th, 2004 12:49 PM
96 200sx, Brake light on constantly? What should I check? Aknosis B14 95-99 chassis 5 Apr 22nd, 2004 12:49 AM
Brake Light problem NewbieNX B11/B12/KN13 82-90 chassis 10 Apr 14th, 2004 10:26 PM
no brake light when tail light is on SEv6 New Member Forum 5 Nov 7th, 2003 08:43 PM
Brake light stayed on this morning mirrortints B15 2000-2006 0 Oct 24th, 2003 07:12 AM
