Old Jun 7th, 2004, 06:43 AM   #1 (permalink)
schebs240
Send a message via AIM to schebs240
Timing chain Guide or swap another KA
Kind of need an opinion, as you all know the timing chain guides are crapola in the KA, So asking for a friend at this point and myself in the future, lets get a vote of hands...
1. Rip out KA put another one in??
2. Shall we begin the evil and difficult task of changing the guides??
schebs240 is offline   Reply With Quote
Old Jun 7th, 2004, 10:54 AM   #2 (permalink)
Chuck
Drifting is for amatures
Chuck's Avatar
Send a message via AIM to Chuck Send a message via MSN to Chuck Send a message via Yahoo to Chuck
Rip out the KA and put a SR in
Chuck is offline   Reply With Quote
Old Jun 7th, 2004, 12:08 PM   #3 (permalink)
azRPS13
I should be azRS13...
azRPS13's Avatar
Send a message via AIM to azRPS13 Send a message via Yahoo to azRPS13
Option one
Got the 1.8L Love
1990 240sx fastback: CA18DET-Walbro Fuel Pump, VLSD, Silvia 2.5" Exhaust, ACT Stage 2- 6 puck Clutch, KYB GR2, Intrax spring and HKS SSQV
Still to Come: FMIC (Iodized Black), S15 T28, Stainless steel Manifold, PS lines, HKS Hi Power, Brake Upgrade(Z32/180sx), and Suspension
azRPS13 is offline   Reply With Quote
Old Jun 7th, 2004, 12:11 PM   #4 (permalink)
schebs240
Please everyone if this was a option it would have been listed..
Old Jun 7th, 2004, 05:22 PM   #5 (permalink)
augimatic
augimatic's Avatar
Send a message via AIM to augimatic Send a message via MSN to augimatic Send a message via Yahoo to augimatic
Rip out the KA and put an RB in?
augimatic is offline   Reply With Quote
Old Jun 7th, 2004, 05:36 PM   #6 (permalink)
Kelso
so close to turbo...
Send a message via AIM to Kelso
rip it out...it will probably be cheaper since probably every junkyard or salvage yeard has a ton of the KA's most likely.
Rules:
1)Search – search, search, search. The search button is in the header of EVERY page loaded on NissanForums.com. Search is the third link in from the right on the header. Please use it before you post. Even though this forum is relatively new there is a lot of good information in the database of previous posts. You might find that your question has already been discussed at length and answered.
Kelso is offline   Reply With Quote
Old Jun 7th, 2004, 06:04 PM   #7 (permalink)
augimatic
augimatic's Avatar
If you go KA, make sure you find a DOHC
Old Jun 8th, 2004, 01:38 AM   #8 (permalink)
Chuck
Chuck's Avatar
i agree.. if you must stay KA, get the DOHC
Old Jun 8th, 2004, 11:25 AM   #9 (permalink)
AlexAtMyNismo
AlexAtMyNismo's Avatar
Send a message via AIM to AlexAtMyNismo
Actually guys, i work for Performance Nissan...and the guides are superceeded....no longer used.... so when you rebuild the KA....you don't even install knew ones... I say keep driving and don't even worry about it.....Drive your KA till it dies....then get another for $200-$300 bucks and throw that one in....
-Alex B.
PERFORMANCE NISSAN
AIM: NeedsMoSpeed
MyNismo.com :thumbup:
Nissan Tuner Parts Solution
AlexAtMyNismo is offline   Reply With Quote
Old Jun 8th, 2004, 02:57 PM   #10 (permalink)
joerc240sx
Nissan Fanatic
Well the timing chain isnt to bad, i have done it a couple times know on the KAe. But if you get another KA do get the de as it opens alot more doors for higher hp for cheaper.
Black 1990 FB
KA24e Built for Turbo /w other bolt-ons here and there.
joerc240sx is offline   Reply With Quote
Old Jun 8th, 2004, 03:06 PM   #11 (permalink)
Asleep
Super Mod - ALL the time!
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
not entirely true. an "e" is just as capable of making as much if not more hp than a "de". one more cam is actually one more moving part whos resistance you must overcome. the twin cam engines are not always the best answer.
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
http://www.cardomain.com/id/our rides
Asleep is offline   Reply With Quote
Old Jun 8th, 2004, 03:53 PM   #12 (permalink)
joerc240sx
Nissan Fanatic
Thats not what i ment by that. the "de" has things that do make it better for turbo aplication over the "e". I have a built KAe in my garage i belive i should now. the advantages of the "de" over the "e" tend to be lower miles (not always), newer, knock sensor, piston oil spurters, more after market support for turbo aplication (not listed in any order)
As for internal modifications of the 2 engines the KAe is cheaper to bebuild. It only has 1 cam, 4 less ports/valves, and a cheaper timing chain. other then that though and the 2 engines are the same.
Black 1990 FB
Old Jun 8th, 2004, 05:32 PM   #13 (permalink)
Asleep
Asleep's Avatar
having one in ones garage doesnt guarantee knowledge or experience. i understand what you are saying though. i just wish the turbo support was as good as you think it is. sure its there, but as of yet, its still pretty pricey to reliably boost and keep a ka engine.
Old Jun 8th, 2004, 06:01 PM   #14 (permalink)
joerc240sx
Nissan Fanatic
I am talking all things relative to the KA engine. sure both have limited turbo support, but the KAde has a lot more support then the KAe. I have had my 90 240 for 3 years now. I liked the idea of a boosted KA, thats why i decided to build a KA instead of swapping. Problems after the build have kept me from ever reaching that goal. But if i where to ever do a turbo KA again i would swap to a KAde and boost it stock short block. If you’re only going for 200-300hp the stock KA should hold up will with some abuse for a couple of years if not more. then with other upgrades like cam, pulley, flywheel, drive shaft, headwork it should last even longer because the engine is making more power at less boost. If the engine dies just pick up another stock KA. its cheaper then building a short block for those power goals. sure if your looking for 350+ rwhp you might want to build a short block with a lower CR, maybe even do some head work and a cam to make that 350+ easier. I would still start with a stock KA and just get a manifold and turbo that support your power goals and run less boost tell the stock KA dies and then build a better short block from there.
man that turned into a long post. again that is my opinion based on my experience with the KA engines, and my knowledge of whats available for it.
Black 1990 FB
Old Jun 8th, 2004, 06:36 PM   #15 (permalink)
Asleep
Asleep's Avatar
i hear ya, not knocking you at all, i hope thats not the tone i set. i met a guy here in az, i always bring him up when ka-t's come up; he has a ka-t at 13lbs of boost and 330whp for about the last 50k miles or so. it can be done, its all about engine management. i havent had the chance to ride in a sr-t yet but ive ridden in two ka-t powered vehicles, one an altima and the other an s14 and i must say, im very impressed with the power they both put out. very nice imo.
Timing Chain for 1996 Altima 1996nissanlover U13 1993-1997 Altima 18 Jan 2nd, 2008 08:30 AM
Write-up: how to remove upper timing chain guide Harris SR-Series Engines (DE/VE) 20 Aug 21st, 2006 03:30 AM
timing chain or timing belt on 97 GXE specalk GA16DE 1.6L Engine 6 May 2nd, 2004 07:47 PM
lower timing chain tensioner cbeebe79 GA16DE 1.6L Engine 7 Jan 20th, 2004 08:22 AM
timing chain guide broken .. 97 pickup dwolf Truck & SUV 18 Oct 19th, 2003 05:16 PM
