Old May 28th, 2004, 02:43 AM   #1 (permalink)
CivicKiller
CivicKiller's Avatar
Brake Lights?
My brake lights were working fine and then i installed a new radio in the car and now the brake lights dont work i replaced the fuse bulbs and still they dont work does anybody know what i can do to fix this problem?
CivicKiller is offline   Reply With Quote
Old May 28th, 2004, 03:13 AM   #2 (permalink)
iron tomm
poster
Send a message via AIM to iron tomm
Bad ground? I had the same probably the first time I installed a head-unit but I forget what the problem was. Double check to make sure you have a good ground and all the wires are connected tightly.
MOFO>YOU
iron tomm is offline   Reply With Quote
Old Jun 1st, 2004, 06:51 AM   #3 (permalink)
schebs240
Send a message via AIM to schebs240
The ground is notorius in the 240 to be crappy on the tail lights just move or tighten
schebs240 is offline   Reply With Quote
Old Jun 1st, 2004, 12:08 PM   #4 (permalink)
Skunk
I also have a problem related to brakes. When i step on the brake the break lights turn on and so do the front ones
Skunk is offline   Reply With Quote
Old Jun 2nd, 2004, 07:37 AM   #5 (permalink)
schebs240
Thats just scary.... See mechanic if ur not playing a dumb joke u have wires crossed.
Old Jun 2nd, 2004, 12:46 PM   #6 (permalink)
Loki
Post Freak
Loki's Avatar
Send a message via AIM to Loki Send a message via MSN to Loki
when you step on the breaks and the light turns on......it means you have NO BRAKE FLUID!......
What doesnt kill you, makes you stronger!....
Loki is offline   Reply With Quote
91 Stanza Gxe brake lights stuck on. -panoptic- Stanza 6 May 18th, 2004 02:53 PM
Brake Lights on a 90 Pulsar NewbieNX B11/B12/KN13 82-90 chassis 0 Apr 9th, 2004 09:18 PM
93 pickup - brake lights out - replaced stop lamp switch and bulbs Austin Nissan Truck & SUV 2 Feb 18th, 2004 09:54 PM
Charging problem: Brake & Charging lights both on tucson_b14 B14 95-99 chassis 8 Mar 28th, 2003 04:32 AM
Battery and brake warning lights CrunchyCookie B14 95-99 chassis 7 Nov 30th, 2002 07:54 PM
