you probablly have not taken the presure off... at the base where the water comes off there is a presure screw,,,,you have to do this when the car is cold.. what you do is you unscrew it all the way out, have someone else turn you car on you will see some steam come until you see water come out then you screw it back in there( the screw) that is the reason you have your car heating up the steam in the system does that, when I change out my radiator it would do that but by doing what I just said I have not had my car heat up since then... let me know if you understood if no I will try and get a pick of the part I am talking about...
